Water ingress
Water ingress was created by Hangman3
Posted 1 year 4 months ago #203117
Hi,
i`m new to the forum & have just picked up a 97 F for my wife. It turns out its going to be a bit of a project. We have owned a few ZR`s in pervious years so are familiar with the engine & gasket changes. But, to start with, I am finding that there is quite a bit of water ingress into this little thing & was wandering if there is already sections on this in the forum could someone point me there please? Or tell me what are the common inlets & how they are generally dealt with.
Cheers in advance, Tim.
Replied by deepfat on topic Water ingress
Posted 1 year 4 months ago #203138
If we are talking windows I can confirm the main body of the glass doesn't leak but all the edges can, the windows probably need adjusting. Puffing some talc around will leave tracks where the waters running from and to but not always where its actually leaking from but a good indication. Normally its either the front leading edge seal or the top seal to the hood/hardtop, the top seal in my experience being easier to fix.
Go to mgfcar.de for good info on what each adjuster does, they go from A to G (or H, I can't recall), it seems daunting at the first attempt (and 2nd,3rd......) but is very satisfying once mastered.
If its water in the boot its 10 to 1 the seals around the rear lights and again talc will confirm this, Good Luck
by deepfat
Replied by Airportable on topic Water ingress
Posted 1 year 4 months ago #203142
Unless someone has had the good sense to upgrade the box type air intake (above the brake servo) for the snorkel type, the poor sealing on that excrescence will provide you with hours of fun drying out the footwell carpets.
Find & fit the snorkel type but make sure you fit a new packer & a bit of sealant won’t come amiss to help either.
Replied by Notanumber on topic Water ingress
Posted 1 year 4 months ago #203166
+1 for changing to the snorkel fresh air intake. The airbox that the F's and early TFs had was abysmal for allowing water into the footwell. It is a popular retro fit and the part is readily available 2nd hand. It cured the occasional wet carpets on my TF
I would direct you to the How To guides and the use of the search feature as there is much to be read here on water ingress
Last Edit:1 year 4 months ago by Notanumber
Last edit: 1 year 4 months ago by Notanumber.
Replied by Hangman3 on topic Water ingress
Posted 1 year 4 months ago #203169
Thanks for the helpful reply`s. Its good to join a forum where people have something to say rather than people that have to say something.
The following user(s) said Thank You: Airportable, Notanumber
Time to create page: 0.531 seconds
