Re:RIDE HEIGHT
RIDE HEIGHT was created by digcot65
Posted 1 year 4 months ago #203121
Hello Ive just taken the MG F for its MOT everything fine but advised to replace number plates as original ones are a bit tatty So Ive bought a new set The MOT tester is really clued up and he said he though the ride height was too high I did say I had pumped it up ,to what I thought I had been told to ,on this forum I have thought it looked high myself but thought that`s the way it should be .If I can have the height,from centre of wheel hub to underside of wheel arch pleaseAlso If I have pumped it up too high,can I buy an adaptor to let some fluid out The pump I bought didnt have that fitting on it Len
Replied by digcot65 on topic RIDE HEIGHT
Posted 1 year 4 months ago #203123
Hello for some reason ,the ride height is too high Cant understand it I thought I had measured it spot on Is there a release valve I can buy,to let some fluid out Len
Replied by Steve on topic Re:RIDE HEIGHT
Posted 1 year 4 months ago #203125
368mm +-10mm @17°c so it will be higher in warmer weather no by much though.
by Steve
Replied by digcot65 on topic Re:RIDE HEIGHT
Posted 1 year 4 months ago #203144
Thanks again Mine is too high ,the MOT man noticed it yesterday and said I should double check it .However he said the height should be 350mm which isnt correct ,so he was thinking it was higher than he thought I have fixed up a plastic bottle which seems quite safe to release the fluid and Ill wear goggles as well Len
Last Edit:1 year 4 months ago by digcot65
Last edit: 1 year 4 months ago by Cobber.
Time to create page: 0.493 seconds
