brake pins. how much force ?
Every other set of brake pads I've changed in my life has been a doddle compared to this.
This will only serve to try and spread the pin!
You should use a pin punch, a punch with a cylindrical shaft and flat cut tip
The general consensus was replace the lot, pins springs everything & like yours the odd pin came out.
Plusgas, patience, perseverance, rotary wire brush & an old G cramp modified from one job it wasn’t intended to do into another. Best of all good fortune.
You can also use these to alleviate the problem; https://www.mikesatur.co.uk/-MGF-and-MGTF-Stainless-Steel-AP-Brake-Pad-Retaining-PinsI doubt you’ll require me to tell you but when you replace with new or doing a pad change clean the locating hole & copper grease the pins. This trouble will then be a thing of the past.
I seem to have recommended Mike Satur's products a few time lately but sadly I am not on commission
I relieved the portion between the calliper cheeks, taking them down to 5.5mm (assuming they were 6mm). I was playing with a surface grinder attachment I scrounged & it was a good exercise. I ground down the tops & worked a thread on the other end & screwed & glued a bobble on. All at zero cost, mind it probably took two & a half hours.
- SundanceUK
I find splitting the two halves useful as you can remove the steel slider plates and remove the build up of corrosion under them which lifts the plate and allows debris in. New stainless slider wear plates are cheap to buy. Stripping the caliper also allows a chance to clean and paint it so its all nice and good again!
Sundance
The drivers side was fine but on the passenger side I couldnt work out why the back of the pads wouldnt sit comfortably against the back of the caliper once the pistons were fully recessed. I then noticed the metal slide plates were higher towards the outside than the inside, forcing the pads in towards the disc. This probably explains why the pad wear was so uneven. I carefully sprayed plus gas then brake cleaner under the plates as far as I could to wash out the build up of dirt to make them sit flatter and also ground a marginal amount off the edge of the pads. All ok there but then I noticed 2 suspicious bits of metal on the ground and realised whilst I had been concentrating on the front sections of the U on these plates, the back parts must have snapped at some point and had come away when the original, worn, pads were lifted out.
Now Ive worked on calipers on a lot of cars over the years but these slide plates are new to me and just seem a confounded nuisance. Will it make any difference if I now fit the new pads and pins ignoring the rear section of these slide plates ?. It wouldnt seem to make any difference to braking and the pads fit snugly but are sufficiently free to move as they should, just as they would be in any other caliper. Is this ok or am i looking at a full caliper rebuild for this, which Im guessing would mean the expense of getting both sides done to ensure fully even braking is maintained ?
My observations of your work via your posts tells me that you understand the full ramifications of doing the job right which is the corollary of getting it wrong & finding they’re not working properly when you need them the most.
- SundanceUK
I used to replace these bolts with stainless equivalents, but they are a little soft when trying to undo again nest time the caliper is stripped down, so now I fit Titanium ones. Very strong and will not corrode. New wear plates can be bought online if they cannot be straightened good enough.
Note, also re-tap the holes in the calipers, it helps. I also fit new bolts that bolt the two halves together. Top of me head I think they are M10 X 65 mm.
Sundance
From Mike Satur's site Ive ordered stainless steel wear plates, a set of stainless pins and springs and replacement outer piston seals.
Is there a technique to plug the end of the flexible hose to stop too much brake fluid draining away after ive i removed the caliper ? Ive only ever swapped calipers over immediately before so not had to leave one off for hours or days, not had to worry about this before .
