brake pins. how much force ?
Replied by Airportable on topic brake pins. how much force ?
Posted 1 year 3 months ago #203446
I’d have them off & on the bench, you can place them at whatever attitude is best for the process you are undertaking. I also really like the Sundance titanium screw idea & his usage of the wire cutters as an Allen bolt removal tool. He might have been watching me, that’s one of my stunts!
Posted 1 year 3 months ago #203452
On the fluid loss front, my dad used to use cocktail sticks.
Cocktail sticks were made of wood & it was harder & as it was me who cleared up the oils etc after I don’t remember much mess.
I now have blanking adapters which overcomes the problem.
Replied by Pharg55 on topic brake pins. how much force ?
Posted 1 year 3 months ago #203453
The best thing is to use a suitable cap fitted to the end of the hose, or another way is to use a hose clamp, or a pair of vice grips, suitably protected with copious layers of masking tape , or pieces of rubber so they won't damage the hose.
by Pharg55
  • Away
Replied by Cobber on topic brake pins. how much force ?
Posted 1 year 3 months ago #203454
Here are some slippers that I made up from steel tube, they’re to put on the vice grip jaws to protect the hose you’re clamping from damage.
I made them @ 35 years ago and they’ve served me very well since.
The trick is only use just enough clamping force to stop the flow, easy as they’re adjustable. Unlike a lot of the dedicated clamps you can get at the shops.
Last Edit:1 year 3 months ago by Cobber
Last edit: 1 year 3 months ago by Cobber.
Replied by Notanumber on topic brake pins. how much force ?
Posted 1 year 3 months ago #203456
Thanks. Thats a great idea. I will wrap some bits of 15mm copper pipe around the jaws.
Replied by neilpinleeds on topic brake pins. how much force ?
Posted 1 year 3 months ago #203459
When I had to take a caliper off my Lancia I bought some red plastic plier type clips to save the fluid. You apply them to the flexible hose and they were circa £5 from ebay.
Posted 1 year 3 months ago #203482
I got scared trying to separate the halves of the calipers so wimped out and have just posted the pair off to Darren with a set of new slide/ wear plates and bolts , a set of new outer piston seals, stainless steel pins and springs and new bleed nipples..
Ive sent the pads to be checked too. I had previously ground a bit off the top & bottom edges to clear the old wear plates so concerned in case they may be too loose when the calipers are set up correctly now. Ive got a pot of Brembo/ AP high temperature paint for when they come back.
Im looking forward to seeing how good these 4 pot APs are when they are setup properly.
Last Edit:1 year 3 months ago by Notanumber
Last edit: 1 year 3 months ago by Notanumber.
Posted 1 year 3 months ago #203483
A good call, especially if you can’t be confident with the outcome. Discretion is the better part of valour.
  • VVC160
  • Van (not yet a camper) driver nowadays
Replied by VVC160 on topic brake pins. how much force ?
Posted 1 year 3 months ago #203525
Back in 2013............... ;)
by VVC160
Posted 1 year 3 months ago #203527
Eek, the pad at the top looks as though it is down below 1mm !
Posted 1 year 3 months ago #203530
It was definitely the right decision to send the calipers away.
They are now on their way back after Darren's team removed the stuck wear plate bolts by welding to them, The new outer piston seals are in as are the new stainless steel wear plates and a set of titanium bleed valves with covers. The calipers needed the pad retaining pin holes to be redrilled in order to take the Mike Satur style stainless steel pins. A pair of new spring plates in stainless finish them off,
Time to create page: 0.636 seconds
