hard top stand ?
hard top stand ? was created by Notanumber
Posted 1 year 2 months ago #204067
Has anyone here made or bought a hardtop stand ?
My hardtop has just been propped in a corner of the garage since i fitted the new softip on the 135 but i keep looking at it thinking it would be better stored in a less precarious way. I'm not sure whether a freestanding frame is best or just to rawlbolt some horizontal timbers to the wall to strap it to.
Replied by Airportable on topic hard top stand ?
Posted 1 year 2 months ago #204068
If you have head room hang it from the garage roof. I have mine on a pulley system where I can drop it on or lift it off, I can do it single-handedly although I like to have spare pair of hands standing by.
  • Away
Replied by Cobber on topic hard top stand ?
Posted 1 year 2 months ago #204069
The proper hardtop for use with an MG
And the correct storage device
Replied by Notanumber on topic hard top stand ?
Posted 1 year 2 months ago #204071
The rafters was my first thought but there isnt enough available height to walk under it ,
Posted 1 year 2 months ago #204075
You don't need much headroom. The clip eyes screw into blind brass inserts fixed from the inside & when on plastic blanks pop in, you barely notice. If the car were in the roof would be hovering a little above the clips, with one more link to settle it for clipping down. The pulleys in the sheaves could do with being twice the diameter other than that it works fine.
Last Edit:1 year 2 months ago by Airportable
Last edit: 1 year 2 months ago by Cobber.
Posted 1 year 2 months ago #204076
That's a nice hood for your helmet Cobbs
Replied by R40MGF on topic hard top stand ?
Posted 1 year 2 months ago #204080
Like Cobber I don't need much room to store my hardtop.
Posted 1 year 1 month ago #204219
Is it safe to hang a hard top from the wall using some sort of hooks to hold the rear window end ?
There isnt the height to string it horizontally from the rafters so mine has been propped against a wall with the back end topmost and the windscreen end on the floor.
It's too likely to be knocked like that so wonder if anyone has hung theirs from a wall and if so how they did it
Last Edit:1 year 1 month ago by Notanumber
Last edit: 1 year 1 month ago by Notanumber.
Posted 1 year 1 month ago #204220
I bought the plastic lid almost by accident having decided against it, “definitely this time & no arguing or rethinks”.
“Yes dear”.
It didn’t stop me from putting a really really really cheeky bit on one in the north east.
We were on holiday when it transpired that I was the most generous, in fact the only generous person.
Explain that at breakfast. I’ve had worse days.
In the preceding years I’ve seen hard tops stored from the frankly reckless through to the ultra cosseted, the chunks missing or broken around the periphery tell stories of there own. But I doubt there was one which has suffered enough not to fit & after the proscribed farting about time, seal.
The way you envisage it as described is the way I would approach it, keeping the whole assembly in shear; find the point of balance across the quarter panels & use those as your anchors.
How you affix the anchors is entirely up to you, but you could do a lot worse than machine screw eyes into blind nuts with a reasonable plate to spread the load. I would guess the stress loading would be better this way than that on my system, where the loading is plane to the surface, granted with four fixing points.
It’s then just a couple of cords from the eyes up to wood screw eyes into the roof timbers.
Last Edit:1 year 1 month ago by Airportable
Last edit: 1 year 1 month ago by Airportable.
Posted 1 year 1 month ago #204239
Whilst looking for something unrelated I found MGMania do some stainless brackets to hang a hardtop from a wall.
I should have copied the info but it didn’t register until later, it’s an age thing.
Posted 1 year 1 month ago #204241
Thanks. Il take a look
Time to create page: 0.561 seconds
