Wet 2005 TF
- generous_dad
The Tiger Seal arrived today and the neoprene sheet comes tomorrow.
I will see what I need for a spacer.
That is Sunday's job.
Weekend after next, the carpet is coming out; seats centre conole, the lot. The stink of rotting foam is taking the pleasure out of a neat and tidy car and definitely not somewhere Mrs g_d will go near.
I have a dream that no carpet will reveal where the water is entering and I will be able to limit ingress.
Starting to ogle CLKs........
- BruceTF135
- Away
Having done my snorkel on the last TF I ought to check this now on my 135. What thickness of neoprene tape is best ?
I can't remember but it is easily compressed. Thicker than the spacers, I would say. 6mm? 8mm? I think the width was about 10mm. You can use the same stuff around the back of the hood. It needs to be closed-cell foam, like neoprene. Open cell foam is basically sponge and will leak!
- Away
- Away
Do you see drops of water on your inner door liner and speaker? If yes, then you have cheater issues. This is also made worse (in my experience) if your car is parked on a slope (facing downhill). It does not seem like much but the small ingress quickly adds up.
The easiest solution (after you have attempted the above) is to put a half cover on car if it sitting outside for longer periods. For shorter periods, I have a couple of small (rectangular shaped) sponges that I place below the cheater on the inside to catch the drops (they rest on the 'ledge') so it does not drip down to the speaker and carpet.
Not so sure about the snorkel. This was a problem on earlier cars but not later ones.
Before pulling everything apart, why not put some paper on your floor the next time it is parked in the rain so you can see where the water is coming in from.
Posting a few photos (of window gaps, water droplets after rain, convertible top condition, etc.) may also be helpful.
You can probably pull back the carpet enough to dry it without having to remove the center console although the seats would need to be removed.
- generous_dad
The snorkel came off and went back on again with a cut sheet of closed cell neoprene and a strip around the sensitive bits.
Evidence of a good seal was the presure needed to engage the rather small nuts.
Hard to see any ingress but all cleaned up and done my best job on it.
The foam that I took off was wet but we have had continuous rain for a month here.
Next weekend, rain or no rain, the carpet is coming out.
Then on to adjusting window as suggested in this thread.
Support on here much appreciated. Thank you.
- generous_dad
The carpet is out and the seats and centre console is back in. The immobiliser/alarm is all working and no unusual lights on the dash.
Thanks once more for the how-tos.
Next step is to try to identify where the wet is coming from. Newspaper, talc as tell-tale.
The carpet was dripping with water when we took it out but no puddles on the car floor.
And no signs of rust (yet).
The footrest area of the passenger has a lot of staining and as step 1 was replacing the neoprene on the snorkel, I hope I have fixed that.
More to come.....
- generous_dad
The carpet went back inside the car today. All tidied up and looking like a proper car again.
6 weeks after the carpet came out.
Staining evident in the passenger footwell and on the carpet in that area.
The cap cover has kept out the rain through the seals and sataified that the car is dry up to this point.
Need to start working on the seals to make it a useable car in the wet.
(And fixing the head gasket........)
Appreciate the support and comments on here.
