Eagle has landed
I tried putting a heater in but science was mystified again as even though it blew hot in the workshop, no more than ten yards away , it had no impact in the garage.
Cryogenics for the inquisitive & an ideal spot for superconductivity research.
It can be quite pleasant in the garage if I heat it before hand My wife says she doesnt know how I can work in the cold ,but I say you think Im out there enjoying myself ,not letting on about heating it
It would be fantastic to have a lift but with inadequate headroom it’ll no more than a dream.
I have an equally cold garage open fronted and facing north east, the planners insisted we had a mono pitch roof to match our neighbours even though theirs is the other side of the garden wall. Due to the garden wall being about sixteen feet high on our side (22 feet the other side!) I have a good sized loft above, however on the ground floor there is only seven feet of headroom.On the point of steel corroding more quickly in a warm garage than outside. My garage has some form of supercooling effect unknown to modern science, even when the mercury has withdrawn to spend the winter months hibernating in its bulb, I have to come outside into the frosty landscape to warm up.
My totally stripped MGB is on a wheeled frame about two feet off the ground, I can get to anywhere I need to get from underneath, I have a sheet of Celotex to lie on so it doesn't feel as cold. I can just get the engine over the front with a block and tackle so it actually works very well. On Thursday I have a bricklayer coming to divide up a building where I store stuff, I will end up with a thirty by twenty building rent free but fifteen miles away, it's not as good as it seems because I have to help the owner out on a regular basis.
I could do with it being ten degrees warmer & being ten years younger.
Tomorrow I’ll be taking off the recently fitted hardtop, so, I can root around in its gizzards.
