Not getting the horn
- generous_dad
However, the horn is no longer horning.
With the steering wheel buttons pressed, I can hear a click from the centre console.
With just a few weeks of TF ownership undermy belt, I am assuming that is one of the relays on the alarm PCB.
Therefore there 12V from the button to the PCB.
Do I assume that a wire comes out of the alarm module and goes to the horns?
Is that it?
And if that is the case, then a simple 12V test at the horn plugs will determine if it is wiring that is the cause?
Is there anything else that I should be looking at?
It's just too cold to be holding on to bits of freezing metal.
- generous_dad
It has been just toooooo cold and now too rainy to do anything.
Will check both and report back here.
The plug terminals are tiny.
- generous_dad
Another way to verify the horns (is your horn singular or plural?) is to run a positive from the battery & pick up an earth locally. Only the slightest touch on the contacts will make you jump, that could be a loud parp or a shower of sparks if you don’t get it quite right
- sworkscooper
John
- generous_dad
WorksC, thanks too. I do have a goodly selection of Torx bits but no Torx+ bits.
I can hear the relay clicking in the centre console so I am suspecting something further along the circuit, nearer the horns (I have 2 oddly because my reasearch shows that Project Drive removed one on my Apr 05 model).
Thanks again for your advice. If only I could bring myself to start touching 4degC metal.
It never occurred to me that that style must be referred to differently, I have pipped & non pipped, I distinguish one to another by marking the pipped offering with red sharpie.
Other close relative tools get the sharpie treatment. It also helps me recover tools which are holidaying in my sons tool boxes & remind them that it’s nice to go away but it’s nice to come home again.
- generous_dad
The Torx+ is a 5 point bit rather than the standard 6 point bit.
It's on my Xmas list.
