Not getting the horn
Not getting the horn was created by generous_dad
Posted 11 months 4 weeks ago #204958
Lovely drive to see a chum this morning as the carpet is indoors still drying out and the snorkel seems to be now fully sealed.
However, the horn is no longer horning.
With the steering wheel buttons pressed, I can hear a click from the centre console.
With just a few weeks of TF ownership undermy belt, I am assuming that is one of the relays on the alarm PCB.
Therefore there 12V from the button to the PCB.
Do I assume that a wire comes out of the alarm module and goes to the horns?
Is that it?
And if that is the case, then a simple 12V test at the horn plugs will determine if it is wiring that is the cause?
Is there anything else that I should be looking at?
It's just too cold to be holding on to bits of freezing metal.
Replied by Cobber on topic Not getting the horn
Posted 11 months 4 weeks ago #204965
Yes the grounding, and both the fit and cleanliness of the terminals
Replied by Notanumber on topic Not getting the horn
Posted 11 months 4 weeks ago #204976
Multimeter or a bulb accross the horn terminals. Get someone to press the horn button. If the circuit is live order a new/ 2nd hand horn. If the circuit is dead its the relay or fuse
Last Edit:11 months 4 weeks ago by Notanumber
Last edit: 11 months 4 weeks ago by Notanumber.
Replied by generous_dad on topic Not getting the horn
Posted 11 months 3 weeks ago #204980
Thanks very much for the advice.
It has been just toooooo cold and now too rainy to do anything.
Will check both and report back here.
The plug terminals are tiny.
Posted 11 months 3 weeks ago #204981
Just one more thing. If it is the relay, does that mean sending the unit to Technozen for replacement soldered relays?
Replied by Airportable on topic Not getting the horn
Posted 11 months 3 weeks ago #204984
Although not as easy to find as other car relays they are available on the internet & if you are confident with a soldering iron & desoldering tackle it shouldn’t be too arduous a job. I am very familiar with the hot end of a soldering iron & wouldn’t think twice about getting stuck in, others who are less cavalier might think twice.
Another way to verify the horns (is your horn singular or plural?) is to run a positive from the battery & pick up an earth locally. Only the slightest touch on the contacts will make you jump, that could be a loud parp or a shower of sparks if you don’t get it quite right
Replied by sworkscooper on topic Not getting the horn
Posted 11 months 3 weeks ago #204998
Technozen is the best solution to the BCU relays , 'IF' you find it is faulty . With my BCU I decided to have all the relays replaced with the more reliable type as the car was a keeper and I didn't want the hassle of taking the darn thing out again. Just be aware of the fact that the unit is held in place by TORX + type screws , the bits are not commonly available but Technozen can supply these if you contact him before struggling to get the screws out .
John
Posted 11 months 3 weeks ago #205008
AP, thank you again. I have soldered but not in the professional category. Would have to take the board out to see how close the adjacent terminals are. Middle son is more experienced than I - might be worth a 4-pack of Doom Bar or whatever he is drinking at the moment.
WorksC, thanks too. I do have a goodly selection of Torx bits but no Torx+ bits.
I can hear the relay clicking in the centre console so I am suspecting something further along the circuit, nearer the horns (I have 2 oddly because my reasearch shows that Project Drive removed one on my Apr 05 model).
Thanks again for your advice. If only I could bring myself to start touching 4degC metal.
Posted 11 months 3 weeks ago #205009
I haven’t heard the term Torx+ before, can I assume it’s a standard torx screw with the security pip in the centre or do we have more / less lobes.
It never occurred to me that that style must be referred to differently, I have pipped & non pipped, I distinguish one to another by marking the pipped offering with red sharpie.
Other close relative tools get the sharpie treatment. It also helps me recover tools which are holidaying in my sons tool boxes & remind them that it’s nice to go away but it’s nice to come home again.
Posted 11 months 3 weeks ago #205016
Good idea, AP. Sharpie.
The Torx+ is a 5 point bit rather than the standard 6 point bit.
It's on my Xmas list.
Posted 11 months 3 weeks ago #205018
Thank you for that it’s really useful. I have both “inside & outside” torx from too small to apply any grunt, through to too big to be relevant for what I get up to these days & as I haven’t been faced with torx+ as yet, I’ll commit their existence to memory & panic if I’m called to strip an item down if so equipped.
Posted 11 months 3 weeks ago #205019
Another thought that has just drifted across my neurones is; if the torx bit had six lobes & the plus has five, surely shouldn’t it be a torx minus?
Time to create page: 0.567 seconds
