TF disappointment
- generous_dad
The seal on the air inlet needed to be made water tight which also meant the carpet had to come out. It will go back this weekend.
Not fully solved door sealing yet but will take a look over the holiday. Using a cap cover on rainy days.
The horn is not working and have yet to have the time to get out there when it has not been raining.
The coolant light came on and I thought it was the connector on the reservoir but it has turned out to be the level of the coolant. And to add to the situation, I have mayonaise on the dipstick.
This would not be so bad if I had not bought it from a well-known dealer who replaces head gaskets on new cars sold.
It will go to Summit Motors in the New Year and we will see what they say.
My questions:
- has anyone had the head gasket problem and now has a dream car?
- what is the going rate to sort out a new head gasket (I will hear it from Summit but would like to hear from more experienced owners and reduce the shock)?
- how am I going to open the discussion with Mrs GD?
Happy Christmas.....
very tricky problem
Mat
- neilpinleeds
I think you are looking at £600+ for the job doing properly.
There are 2 types of replacement head gasket depending on the height of the cylinder liners so its possible the dealer who sold it to you fitted the wrong type. Have you spoken to the dealer about them changing it again, either free, parts only or at a reduced labour rate. A discrete comment about being a member of an owners' forum and the power of social media could help you during such a conversation
A head gasket change can be done at home with average DIY mechanic skills. Dozens of people on this and the other forums have done this job so there is a wealth of information. No reason to pay anyone else to do it- the only part that it could be worth getting someone to do would be to get an engineering shop to check the cylinder head for any minor warpage and then skim it if required. The rest is all DIY, A reconditioned 135 cylinder head is £ 325 if there turns out to be a serious problem with the head (not that i would expect that to be the case) and good, checked 2nd hand ones would be a lot less than that.
It would be ideal to get the car under cover whilst you are working on it if you can. if you dont have a garage or car port it's time to ask neighbours and nearby friends if they can help with getting it under cover so you can work on it for a couple of days.
[size=10pt]Mark[/size]
95 MGF
- sworkscooper
John
- generous_dad
Nota, thanks too. I have a B and had to swap a head for Peter Burgess one. But a B and a TF are very different animals.
The TF was supposed to be my daily driver.
Your confidence building enthusiasm is much appreciated but I do want it to be fit and forget and I dont have the time to spend on it at this time of year.
Summit mentioned exactly the same as you when I called them this morning. The liner height is something they will be considering and a rubber gasket as opposed to ML type. I am not sure I would be able to decide as I have no experience of them.
To be honest, I have lost faith in the dealer despite the number of Fs and TFs they sell per month. If they got that wrong, I do not trust them to get it right.
And I would expect them to put up a fight as it is out of 3 month warranty. Their business is bigger than anyone else selling these cars and after all is said, they are just secondhand dealers. If I want to keep the car, it has got to be done with confidence.
John, thanks for the reminder about Rough Luck. No personal experience of them. I have committed to Summit.
Fortunately, we have RAC At Home and I will give them a call when everything opens again in the New Year. They can take it to Summit and I will report back.
The horn will be a relay change by Technozen but after the engine is back in service.
At least the car is dry inside now.
If only the head gasket was as leakproof as our joint account - Mrs GD has been out on the Christmas spend. That might be to my advantage........
Great forum. I look forward to posting some good news about the car nest year.
- bryan young
- BruceTF135
- Online
Head gasket replacement isn't such a big deal. I've never done it on the TF but on my MG Midget I used to have the head off once a year to sort out the exhaust valves and I reckoned on an afternoon to do the job. But I was young then; now I'd probably get it done. The mobile MG guys seem very reasonable. They come to you but it will reduce travelling costs if they are closer, so here are a few well-known people and their locations. Some even have prices for the job on their website.
https://mgroversolutions.com/ - Sussex
http://www.mg-rovermobilemechanics.com/ - Derby
https://www.roughluckracing.com/mobile-head-gasket-failure-hgf-repair/ - York
http://www.mjsautoandmarine.co.uk/prices/ - Sussex south coast
Hope this helps.
- generous_dad
All very helpful and supportive.
Searched for Graham Underwood MG brace with no results. Any link available please? A bit new to F/TF world.
I think I solved the incontinence problem but the brace is a good idea.
For instance, after I replaced the underfloor coolant pipes with SS pipes, I discovered a few drips at one hose connection, the jubilee clip needing tightening. SS expands more than mild steel, which can work a jubilee clip a bit loose. Check the for a drip and try tightening the jubilee clips.
I would suggest adding coolant dye, drive the car and then look at every hose connection with a black light, looking for glowing coolant drips. Also check around the inlet manifold and the engine coolant rail pipe.
95 MGF
