Sheer pins for steering column ?
Sheer pins for steering column ? was created by Notanumber
Posted 9 months 4 weeks ago #205555
Does anyone happen to know a source for nylon sheer pins ? I had to drill out a nylon sheer pin to separate the front shaft on an MGF steering column that Im modifying to use in a project car. It would be good to replace the pin with the same thing now it's being reassembled.
Replied by Airportable on topic Sheer pins for steering column ?
Posted 9 months 4 weeks ago #205557
I’m not familiar with the makeup of the column, although that is likely to change if the chap from whom I’m trying to buy an adjustable version were to answer emails & we can agree on a price.
Where about is the pin & what function does it perform, is it a sheer pin, what diameter & length, has it a rivet or screw head?
Replied by Notanumber on topic Sheer pins for steering column ?
Posted 9 months 4 weeks ago #205559
Ive never seen a steering column wearing any makeup but thats by the by.
The front shaft and the shaft that goes down to the motor are joined in a tube. The front shaft is permanently welded in place but the other, which is splined is secured by a nylon sheer pin with blind, flush ends.
Posted 9 months 4 weeks ago #205563
Right, the only bit I fully understood was my rather dumb typo.
I take it that in the case of an accident the pin shears & the column telescopes whilst the air bag deploys.
If that is the case & you want to retain that level of safety, you really do need something approaching the original.
If you can measure the diameter I’ll have a rummage in my plastics box, although most of samples in there are probably too resilient.
Replied by MGB281 on topic Sheer pins for steering column ?
Posted 9 months 4 weeks ago #205572
Its got nothing to do with the air bag, in a collision it might shear and allow the column to telescope about 10mm, I think the only real puropse is to hold the column together during assembly. However as always Google and Ebay are your friends;
Plastic Rod Bar Round Acetal Acrylic Nylon PTFE 2mm to 30mm Dia. various length
Buy It Now
by MGB281
Posted 9 months 4 weeks ago #205573
Those four pictures are how my plastics box should look. That interspersed with sheet & amorphous off cuts.
I wasn’t implying that the pin was instrumental in deploying the airbag, just that whilst one was shearing the bag might be coming to smack you one in the face.
Last Edit:9 months 4 weeks ago by Airportable
Last edit: 9 months 4 weeks ago by Airportable.
Posted 9 months 4 weeks ago #205575
I need a new brain ! I searched for ages for nylon shear pins, assuming these were sold as dedicated parts for a number of similar applications and I just wasnt using the right search criteria. it hadnt crossed my mind to look for lengths of nylon and acrylic rod which is exactly what they are. That will do nicely.
Posted 9 months 4 weeks ago #205576
We are all in the same boat, judging by re reading some of my posts I wonder what planet I was on when I wrote it.
I did actually think it might be simpler to tap a thread in the outer tube and put a grub screw in.
by MGB281
Posted 9 months 4 weeks ago #205578
If you measure the diameter & what sort of length would suit, I’ll tip my box out & have a root. Obviously no promises, but I’ll stick a bit in a jiffy & shunt it down to you if I’ve anything like.
It’ll also give me the opportunity to clear out scraggy ends, mouse droppings & dead spiders.
Replied by Cobber on topic Sheer pins for steering column ?
Posted 9 months 4 weeks ago #205579
What a great offer not only can he get the bit he needs…. But with bonus mouse droppings and dead spiders! :lol:
Posted 9 months 4 weeks ago #205581
I’m not sure of the types of spiders they would be, but I have a number of different types & sizes. If you let me know your preference I’ll see if I can oblige.
Big Bugger or fat sod with long legs won’t do, you would have to use Linnaean binomial nomenclature to ensure the corpse is correct.
Mouse shit is mouse shit & that’s optional.
Posted 9 months 3 weeks ago #205590
Thanks Mike. Do you have a short length of 3mm nylon bar please ?. An inch of the stuff would be plenty
Last Edit:9 months 3 weeks ago by Notanumber
Last edit: 9 months 3 weeks ago by Notanumber.
Time to create page: 2.055 seconds
