Link Assembly - Long - Trailing Rear Suspension - LH Rear
The left and right link assemblies appear to be handed but otherwise identical in length etc.
The component that locates at the mid point of the car appears to be common, the component at the hub end would seem to be handed according to whether it is for left or right side of the car. I have not inspected the thread on the bars but can't see a reason for that to differ between left or right side of the car.
So the question is this. Has anybody identified a part number for just the outer end components that are handed? If so can they please let me know what that/they are is please?
Replied by MGB281 on topic Link Assembly - Long - Trailing Rear Suspension - LH Rear
Posted 8 months 1 week ago #206084
The ball joints on the end are Ford Mondeo/ Jaguar X type track rod ends. I am certain that they are from the MK3 but possibly from a MK2
by MGB281
Replied by Delbourt on topic Link Assembly - Long - Trailing Rear Suspension - LH Rea
Posted 8 months 1 week ago #206085
Thank you for that. Tomorrow will dictate the need, or not, for replacement when subject to MOT and followed by 4 wheel tracking.
At the moment I can’t release the inner end of the off side from the rod itself (I.e. the nut is good and stuck hopefully a little heat might resolve the issue).
I think the inner end “rose joint” might be NLA.
Posted 8 months 1 week ago #206100
The inner spherical joint is almost certainly available but the difficulty is locating it. I did trawl suspension joints on eBay and found quite a number but not the right size, the ones that I did find (mostly Jaguar) were quite cheap though.
by MGB281
Posted 8 months 1 week ago #206103
I actually ad to remove both of mine and get them very hot before they would move. Even then it took a lot of force too and fro plus liberal amounts of Plusgas. Make sure that you take the correct tracking figures with you especially for the rear suspension. ATS did mine and their programmed in figures are incorrect. I went back and got them to do it properly, you wouldn’t believe the difference.
by MGB281
Replied by Delbourt on topic Link Assembly - Long - Trailing Rear Suspension - LH Rear
Posted 8 months 1 week ago #206121
The best option I can think of is to find a bush that fits the eye and press a new one in.
There are outfits that make various sized bushes as you might expect. Just need the dimensions! If anyone has a used one that they can measure we might get somewhere - eventually- with a bit of luck.
Ford or similar ball joint ends would cater for the other end.
Posted 8 months 1 week ago #206127
The Ford ball joints are the correct ones so best to use them. The spherical bush needs to be retained if possible, with a polybush type insert there will be conflicts as the suspension moves. I am currently nearer Cobber than the U.K. so cannot check how the arm is fabricated but not hard to machine a socket for an off the shelf spherical bush, sadly most of them have a 12mm bore.
by MGB281
Time to create page: 0.485 seconds
