Temporary Loss of Electrical Power
- GreenComet
- Apprentice MGer
On a spirited drive today the battery light came on for a few seconds and I think I lost electrics (the steering felt unassisted).
The issue appears to have gone completely for now, however is this a typical symptom of a bigger or growing problem?
Many thanks
Matt
- GreenComet
- Apprentice MGer
Replied by GreenComet on topic Temporary Loss of Electrical Power
Posted 7 months 1 week ago #206494Another update... When I turn the key to 1st stage (ie engine off but car electrics primed) I don't get a battery light.. Does this mean my alternator is dying?
Matt
It could be something as simple as the exciter wire having a loose connection.
If someone has replaced the original incandescent bulb with a modern LED bulb this will also prevent the alternator from exciting as it has less resistance to the original incandescent bulb.
- GreenComet
- Apprentice MGer
Posted 7 months 1 week ago #206532Car off: 12.06v
Car on: 11.46v
Does anyone have a recommended next step? From reading this guide, my battery definitely isn't charging
https://www.the-t-bar.com/forum/22-cjj-s-guides/90639-testing-the-battery-and-charging-circuit
If it’s with the engine running does the voltage rise if you give it some revs?
The fact that the alt light isn’t coming on with the ignition on / engine not running means you alternator probably isn’t going to charge.
1st thing to do is replace the light bulb for the charge light. To do this you need to remove the instruments to gain access.
Replacing this bulb is much cheaper than replacing the alternator, so it doesn’t matter much if the bulb isn’t the cause of your problem.
The next thing to check is the wiring connections to the alternator, if they’re ok then maybe your alternator has shat itself.
- GreenComet
- Apprentice MGer
Posted 7 months 1 week ago #206535https://www.the-t-bar.com/forum/9-mgf-tf-pitstop/97429-alternator-failed
- GreenComet
- Apprentice MGer
Posted 7 months 1 week ago #206536Please Log in or Create an account to join the conversation.
- GreenComet
- Apprentice MGer
Posted 7 months 1 week ago #206537Please Log in or Create an account to join the conversation.
- GreenComet
- Apprentice MGer
Posted 7 months 1 week ago #206539Please Log in or Create an account to join the conversation.
Replied by David Aiketgate on topic Temporary Loss of Electrical Power
Posted 7 months 1 week ago #206546David
Replied by Notanumber on topic Temporary Loss of Electrical Power
Posted 7 months 1 week ago #2065472003 TF 135 sunstorm
