WHEEL STUB REMOVAL FRONT HUB
WHEEL STUB REMOVAL FRONT HUB was created by digcot65
Posted 6 months 2 weeks ago #206726
How do you remove a front hub wheel stud MG TF
Replied by Airportable on topic WHEEL STUB REMOVAL FRONT HUB
Posted 6 months 2 weeks ago #206728
If you simply want to remove a stud from the hub casting, I would find a nut of the appropriate size, run it down the thread until as much of the thread is within the nut & give it a stout clout with a big hammer. They have grooves rolled into the blank end which cut into the casting when they are pressed in, so “just a clout will get one out”.
The following user(s) said Thank You: digcot65
Time to create page: 0.693 seconds
