Fuel delivery Problem
OH and don't dry run the pump!
The following user(s) said Thank You: Toyman
Fuel pump relay is part of Engine Management Relay Module. This module consists of 4 relays put together in one box and is located at the rear of the engine ECU. One of these 4 relays if fuel pump relay. There is no separate fuel pump relay on your car.Unfortunately I'm in Perth. but thanks.
You don't happen to know where the Relay is located, or maybe it does not have one?
by Roverlike
Yeah.......I probably should've mentioned that!
Time to create page: 0.491 seconds
