Init Fail
Received my pscan today but unable to connect to either of my MGFs. One Oct 99 vvc the other Mar2000 steppie. So as I understand they are both mems 1.9.
Connect to car flashing LED and k line check go through the ignition off'on 'off routine and all I get is Init Fail.
I also have a Rover 75 cdti and have no problem with that.
Any help would be greatly appreciated
by Postie
A steppie is a Step Speed right? (I had to google that).
If it has a step speed transmission then the engine ECU is MEMS3
I just (as in today) collected a lot of data from a Rover 45 with the CVT transmission. I believe that this is the same thing as the Step Speed in an MGF.
Once I have written the code for this I will want you to try it out.
by pscan.uk
Thanks again.
I'll be more than willing to help if I can.
Tried mems 3 on the steptronic and it connected.
There is a load of conflicting info about MGFs around the crossover from mk1 to mk2.
Both mine only have a single pre cat O2 sensor (a la 1.9), Coil packs (mems 3)
Even the MGF guru Dieter Koennecke has some discrepancies.
https://www.mgfcar.de/library/ENGINE_MANAGEMENT_SYSTEM_MPi_MEMS_1.9.htm
States mems1.9 until VIN 511xxx
And yet
https://www.mgfcar.de/library/ENGINE_MANAGEMENT_SYSTEM_%20MPi_VVC_MEMS_3.htm
States mems1.9 until VIN 522572
Mine are 513646 and 518336
And yet
Last Edit:5 years 6 months ago
by Postie
Last edit: 5 years 6 months ago by Postie.
The Step Speed transmission is actually controlled by the MEMS3 ECU, it doesn't have a separate transmission ECU.
The MEMS3 code in pscan already collects error codes for both engine and transmission so you already have that.
The work that I need to do now is live data from the transmission.
by pscan.uk
The following user(s) said Thank You: Postie
Time to create page: 0.512 seconds
