Releasing the speedo clock pod 7 years 2 months ago #176257
The outer cowl of the dials is held in with 4 screws, two shorter ones here
and here
and two others here
and here
You can now ease the cowl forward to swivel the cowl anti clockwise and out of the way. It may require a bit of wiggling This means you don't have to remove the steering wheel or disconnect the mirror control and dimmer switch
The instruments are also held by 4 screws, two here
and here
two here
and here
It is now possible to pull the instrument pod forward. This allows you to change bulbs etc.
As usual replace by reversing these instructions. Top tip - use a magnetic screwdriver. losing one of those screws into the depths of the dash is a pain!
The following user(s) said Thank You: talkingcars, Andy Lawrence, BruceTF135
Releasing the speedo clock pod 3 years 9 months ago #193924
Hi David I can’t download the pictures, can you help?. The binnacle on my car rattles so I’m trying to remove it to see how it can be re-secured.
Releasing the speedo clock pod 3 years 9 months ago #193926
Try this How to thread #32225 explains binnacle removal which is the first step. Broken binnacle mounting tabs is a common problem
https://www.the-t-bar.com/forum/54-how-tos/32225-binnacle-repair?start=0#32225
Last edit: Post by Gavin207. Reason: Replace link
Time to create page: 0.100 seconds
