Instrument cluster removal 1 month 6 days ago #206545
Remove the steering column nacelle It is held with 3 screws underneath. 2 near the stalks and 1 at the bottom under the fusebox cover.So, the outer cowl of the dials is held in with 4 screws, You can now ease the cowl forward to remove the connectors from the dimmer and the mirror control. The instruments are also held by 4 screws, It is now possible to pull the instrument pod forward. To remove the pod release two long grey connectors and a short yellow one.
Time to create page: 0.092 seconds
