I was looking for a way to stop the age old problem of the carpet popping out at the edges. It ruins the look of the car every time you get out and there is a bit of cream foam staring at you.
So I bought some of this from Halfords to stick the edge of the carpet down.
Extra strength hook and loop sticky backed Velcro.
I cut a length to cover the curve.
Placed it under the edge of the carpet and used a marker pen to mark the edge of the curve.
And trimmed it to suit
Cut a length of the opposite Velcro and stuck them together
And trimmed that to match
Next I pulled the edge of the carpet out and cleaned the metal with thinners to degrease it.
And did the same to the carpet
I then removed the backing from one side of the Velcro
and carefully stuck it to the metal so that it followed the curve.
Stick the opposite piece of the Velcro to the inside of the carpet.
And push the carpet back into place.
It should now stay where you put it.
Do the same to the passenger side and there should be no more swearing
