The leather gear stick gaiter isn’t one of the most talked about items, but there may be times when you need, or want to change it.
You might fancy a change of colour, or as in my case, the existing one may be damaged.
The procedure is fairly easy and doesn’t require any great skills.
The only special tool you will need is a lever that won’t damage the console. I have a plastic trim removal tool that does the job. You can use screwdrivers etc, but you run the risk of stressing the plastic or chipping the paint if painted.
The first thing to do is buy a new gaiter. I bought mine off e-bay for £5.99 from a seller called Topgaiters.
To remove the gaiter we must start by removing the gear knob.
Depending on what knob you have depends on the removal procedure, but the LE500 one is held on by a spring clip, so one good tug of your knob and it should come off in your hand.
Next you need to lever out the bottom ring that holds the gaiter in place. It is held in by 4 clips at the 12, 3, 6 and 9 o’clock positions. You should be able to carefully lever the rear out until the clip releases and then the ring will pull clear.
Be careful, as the ring is only plastic and may be painted. Do not use excessive force.
Once the lower ring has been released the gaiter will slide up the shaft and can be removed.
Undo the 4 Philips screws under the bottom ring and slide the cover up and over the gaiter.
The top of the gaiter has a fixing that grips the gear stick.
Turn the gaiter inside out and you will see that this is held in place by 2 rubber bands.
Use a screwdriver to lever the rubber bands off
And pop the fitting out ready to fit in the new gaiter.
The original gaiter is glued to the lower fitting using double sided tape. Carefully peel off the old gaiter.
It may be worth marking the fitting so that you remember where the rear seam goes.
Once this is removed, you are now ready to fit the new gaiter.
Fit the upper fitting.
Turn the gaiter inside out and lever the rubber bands over the fitting to hold it in place. Make sure that the top fitting is level and the leather is not gathered.
Now turn the gaiter the right way round and offer it over the bottom fitting. I didn’t bother gluing it.
Make sure it is level all the way around and the rear seam lines up with the mark you made.
Now slide the outer ring down the gaiter and secure to the lower fitting with the 4 Philips screws.
The gaiter is now ready to refit.
Slide it down the gearstick and position the lower ring. If you get it just right you should be able to push it into place until the 4 clips click in.
Now refit the gear knob and you are done.
