Fitting an LE500 bumper to a TF 10 years 5 months ago #136395
  • cjj's Avatar Topic Author
If anybody out there told you that an LE500 bumper fits straight on to a TF, then they lie like a cheap watch.
The idea was to update the front of the TF with the shapelier LE bumper, and would be an easy fit, or so I thought.
While I like the TF front, the rectangular black bit always looked a bit out of place.
So I bought the LE500 bumper which has a bit more shape to it. You can see the difference here.
The good news is that the screws along the top of the slam panel are the same, and the fastenings to the wings are the same.
The adaptor that secures the fog light to the bumper has six screws. The top six screws on each bracket are different spacing to the bottom 3, so the unit will only go on the correct way up.
Unfortunately, the bad news is that the rest of the fittings are different
The grill and air dam securing points are different. They need some "modifying" to fit.
But the biggest problem that I found is that the holes in the front of the bumper where the 2 splined bolts secure the bumper to the armature didn't line up.
On the old bumper, the holes lined up with the second hole up (you can see it has a nut welded on the back). The LE500 bumper holes line up with the very bottom hole, which has no nut.
So, off came the armature, opened up the bottom hole with a drill
Found suitable nuts
and out came the welder
then a coating of Hammerite to stop the old rust
and back on with the armature
The bumper now fits.
Got to admit, when I took it for spraying, I was tempted to go with the orange, but I resisted and went with the Royal Blue and an LE500 MG badge.
The finished article
Last edit: Post by cjj.
Fitting an LE500 bumper to a TF 10 years 5 months ago #136396
Nice job :broon:
Fitting an LE500 bumper to a TF 10 years 5 months ago #136397
  • Bertl's Avatar
  • Bertl
  • in the middle of the midlife crisis
as ever,
Rob
Fitting an LE500 bumper to a TF 10 years 5 months ago #136398
Yes after dismantling a LE 500 there are lots of small slightly different to the oe mg rover parts,it still suprises me that so called mgf specialists on ebay still sell 2002 to 2006 MGTF parts as LE500.
Sources tell me the burnt orange bumpers had problems with the paint peeling and the LE500 bumpers called back or wasnt supposed to be fitted made there way out of longbridge and on to ebay
Last edit: Post by GT MG SPARES LTD.
Fitting an LE500 bumper to a TF 10 years 5 months ago #136413
Hi good job looks great, just thinking would you want to sell the fog lamp brackets from the old bumper?
Fitting an LE500 bumper to a TF 10 years 5 months ago #136421
Looks the business roughly how much does the paint job cost just to give me an idea as I would like to get the back end passenger side of mine sprayed but have no idea of respray prices :beer:
Fitting an LE500 bumper to a TF 10 years 5 months ago #136428
No idea mate, I had the whole car re sprayed at the same time.
Fitting an LE500 bumper to a TF 10 years 4 months ago #136458
Looking good! :broon:
Time to create page: 0.114 seconds
