How to check and replace front subframe mounts.
How to check and replace front subframe mounts. was created by cjj
Posted 10 years 11 months ago #137270Unfortunately, due to their design and position, they are prone to corrosion, which can build to an alarming level in a relatively short time.
This is a common fault of these cars and should be checked occasionally as it is a structural point and could have serious consequences if they fail.
To check the mounts, you need to remove the front bumper.
The Front bumper is held in 4 main places.
Across the top of the grill (5 x Cross Head Screws)
Inside the wheel arch (2 x Cross Head Screws on each side)
Underneath the radiator (2 x Cross Headed Plastic Screws)
In the recesses each side of the number plate (2 x T50 Torx Screws)
I started by removing the 5 screws at the top.
Then I removed the front wheel arch liners. There are 2 metal cross head screws on the front edge of the arch
and one on the rear edge.
and 3 plastic trim cross head screws at the back of the arch, holding the liner in place.
Once all of the liner screws are removed you can remove the liner. Start by peeling the liner from the front of the arch
Until the whole liner is released and it can be pulled out over the wheel.
Then remove the 4 cross headed screws (2 each side) holding the bumper to the wing.
If you have fog lights, you can now disconnect the plugs to each light. Using thumb and forefinger squeeze (or push) the rear edges of the plug together to release it and pull towards you.
While you are under the car, there are 2 plastic trim screws that secure the underside of the bumper to a central strap. Remove these. You may need a right angled screwdriver or need to remove the plastic panel behind to gain access with a normal screwdriver.
Now lie something soft in front of the bumper in case it falls to prevent it getting scratched.
You can now remove the two Torx screws holding the bumper to the chassis.
You can now carefully remove the bumper by pulling it towards you from the centre. Place the bumper somewhere where it cannot be damaged.
With the bumper removed, you can now inspect the front mounts.
This is how mine looked on a 2004 TF160.
They are 9 years old (60,000 miles) but look far more corroded than any of the other body/subframe parts. This is why you need to inspect them and cannot rely on just looking at the condition of the subframe.
Next, you need to slightly raise the body so that you can take the weight off the subframe mounts. You only need to raise it just enough to take the weight off, if you raise it too much the subframe will be hanging by the mounts and will fall when they are undone. Don’t use the subframe as a jacking point as that would defeat the object.
Once the weight is off the subframe mounts, you can remove the two 13mm bolts that hold the mount to the bodywork.
The inner bolt uses a captive nut
Be careful when removing this bolt as it will most probably shear off. Try to clean as much rust off it first and soak it in release oil. If it does shear off, the nut will need to be drilled out and rethreaded with a helicoil kit, or similar.
The outer bolt has a nut on the top, so even if this snaps, you can replace it with another nut and bolt.
Once the two bolts have been removed you can remove the main bolt that holds the mount to the subframe.
Remove the mount and replace with a new one. I also fitted new High Tensile Allen Bolts.
Loosely refit all bolts and lower the body back down onto the subframe.
Now torque the bolts up to the correct value.
The large main bolt to the subframe should be torqued to 100 Nm
The two 13mm bolts to the body should be torqued to 30 Nm
Once the new mounts are fitted and torqued, you can now refit the bumper and wheel arch linings.
If you find that you can’t get much movement when raising the bodywork, you might want to loosen the centre bolt on the cross braces, which bolts through the bracket on the spare wheel well.
- adamelphick
Replied by adamelphick on topic How to check and replace front subframe mounts.
Posted 10 years 11 months ago #137274I think I had better check the front mounts on Felix as he's an '04 and considering the clonk at the rear (still to determine what it is!) I bet his mounts are cream-crackered too!
- Andy Lawrence
Replied by Andy Lawrence on topic How to check and replace front subframe mounts.
Posted 10 years 11 months ago #137278It seems to me that there was a lot of cost cutting done on the development of the TF. :oops:
WHALE OIL BEEF HOOKED
- adamelphick
Posted 10 years 11 months ago #137279Andy the tyre man wrote: Last time I had my bumper off mine they looked in perfect condition for a 1999 'F!
Megs are fine too and she's 1998 ... unfortunately the quaity of rust prooffing got worse as the years went on - hence why there are so many really well preerved F's and some really shoddy TFs.... having said that it's all down to how you look after them too.
Replied by cjj on topic How to check and replace front subframe mounts.
Posted 10 years 11 months ago #137293Please Log in or Create an account to join the conversation.
- Tourbillon
Replied by Tourbillon on topic How to check and replace front subframe mounts.
Posted 10 years 11 months ago #137294TB
Replied by Argen69 on topic How to check and replace front subframe mounts.
Posted 10 years 11 months ago #137349Anyway congrats on another excellent guide!
Replied by graham1 on topic How to check and replace front subframe mounts.
Posted 7 years 4 months ago #180150Please Log in or Create an account to join the conversation.
- Andy Lawrence
Posted 7 years 4 months ago #180152You may need to take the bumper off though.
Replied by helsbyman on topic How to check and replace front subframe mounts.
Posted 7 years 4 months ago #180163BILSTIEN DAMPERS, 4-2-1 MANIFOLD, HEAD WORK BY SABRE.
Posted 7 years 3 months ago #180357Please Log in or Create an account to join the conversation.
Replied by talkingcars on topic How to check and replace front subframe mounts.
Posted 7 years 3 months ago #180358
