  • 2
How to remap your car. 8 years 1 month ago #166892
  • cjj's Avatar Topic Author
I hear a lot on the forums and Facebook about people spending hundreds of pounds remapping their cars and there are many reasons people do it. It isn’t necessary, but with the correct map, you can cover ground a lot quicker and you can save fuel too.
There are companies that will remap your car for you, but it is a fairly straight forward task if you decide to do it yourself.
Basically you need to locate the map and either make alterations to tune it for modern roads, or you can buy a more modern map and install that. I opted for buying a new map. These are available online or from appropriate shops.
Finding the location of the map takes a bit of detective work.
It is important that the old map is removed before installing a new map as not only could 2 maps in the same place cause damage, it can cause problems if the wrong map is referenced during use of the vehicle.
I found mine in the pocket behind the passenger seat, it has served me well and ensured smooth travelling over thousands of miles. Warning, not all not all Fs and TFs are equipped with map pockets.
I removed the old map
And after checking I had the latest and correct map for my car
I installed the new one.
The age of the map can be identified by a code embedded on the map. In this case you can see the code says 2016 and UK. This combination of numbers and letters refers to when and where the map is for. You can find more information on the meaning of these codes on the manufacturer’s website.
Installation was very quick and went without problems.
Installing an out of date or incorrect area map will not necessarily damage your car, unless the out of date information overrides your common sense when the directions no longer exist. If you install an out of date or incorrect area map by mistake, it can easily be removed and a new one installed at any time.
I now find my car drives a lot more efficiently.
Although this was carried out on a 2004 MG TF160, the procedure is similar for most makes of car.
I hope this has helped people.
The following user(s) said Thank You: Leigh Ping, Bob, cairnsys, The driving dutchman, mgtftone, Notanumber
How to remap your car. 8 years 1 month ago #166893
:clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap:
I thought this might qualify as one of John's Master Classes. It most definitely does :broon:
Nice one Clive
Last edit: Post by cairnsys.
How to remap your car. 8 years 1 month ago #166897
Brilliant! I was halfway down the page before I lolled! :D
How to remap your car. 8 years 1 month ago #166906
I can't install a map in my TF it has no pockets :nonod:
Fantastic how to :broon: I'm going to adapt your helpful and informative post and use it on my ZT.It has map pockets :woohoo: Thanks Clive :beer:
How to remap your car. 8 years 1 month ago #166909
Great How to!
I don't have the confidence to tackle this job myself. :nonod:
Can you recommend a specialist who could do this for me, and what sort of cost should I expect?
Peter
How to remap your car. 8 years 1 month ago #166910
My mate Thomas Thomlinson does good work with mapping for cars. Send him a message, known on here as Tomtom! :bust:
How to remap your car. 8 years 1 month ago #166912
ive just remapped my tf.........but ive got the 2015 version..........bargain at only 49p
they are available from home bargains.............the price on front page reads £7.99.......but what a bargain 49p and a quality aa mapbook :woowoo:
How to remap your car. 8 years 1 month ago #166913
Hmmm. I think there was a problem with the 2015 maps.
How to remap your car. 8 years 1 month ago #166915
Great How to!
Peter
I could do it for you, but I would need to charge £500 plus travel costs.
How to remap your car. 8 years 1 month ago #166916
like what? :pop:
The following user(s) said Thank You: mgtftone
How to remap your car. 8 years 1 month ago #166918
There was a dodgy batch that were recalled.
How to remap your car. 8 years 1 month ago #166921
I read somewhere the 2015 atlas was ok, but the roads were in the wrong place. And that is why there are so many Road Works around the country. :bust:
Tony B)
Ps Great initial mapping topic :broon:
  • 2
Time to create page: 0.133 seconds
