Engine bay cooling mods... options/ideas
- Diesel Destroyer
Engine bay cooling mods... options/ideas was created by Diesel Destroyer
Posted 11 years 5 months ago #116592Not nearly enough air flow to allow for effective cooling.. So a few have looked at modding bits n bobs to aid in ari flow
Andy Watson has a rather nice rear :slapme: boot lid I mean.. with some custom air vents...
Ive opted for Koos air vents on the side... Making some DD scoops for under the car.. and some subtle mods to the boot lid vents..
The Koos vents smoothed in..
Some vents from another boot lid chopped into my boot lid
The underside will be modded to open the hole up as big as it can go without letting water into the boot..
So.. anyone else done anything else? Pics? Ideas? Comments? Thoughts? Haters? lol
Replied by Davem on topic Engine bay cooling mods... options/ideas
Posted 11 years 5 months ago #116594http://www.the-t-bar.com/en/forum/32-wanted/88391-engine-bay-fan?limitstart=0
Replied by cjj on topic Engine bay cooling mods... options/ideas
Posted 11 years 5 months ago #116595Please Log in or Create an account to join the conversation.
- Diesel Destroyer
Replied by Diesel Destroyer on topic Engine bay cooling mods... options/ideas
Posted 11 years 5 months ago #116596Bu t I might struggle to get them in... with the ITBs and the pipercross box..
Found these though.. which could be fitted into the bootlid itself..
- Diesel Destroyer
Posted 11 years 5 months ago #116597cjj wrote: I was considering similar, with a high volume rad type fan mounted under the slats with a temp sensor. This would force hot air out of the top vents and draw cooler air in through the side vents and under the car. It might be possible to get a more efficient fan to replace the one on the side vent so that more air is drawn in there too. Let's face it, I doubt MG went out of the way to get the best fan they could.
Ive been looking at high CFM fans too.. I plan to fit a manual overide switch on my fan too...
http://www.cbsonline.co.uk/product/8%22_Electric_Cooling_Fan_FAN8
Posted 11 years 5 months ago #116598I would measure up so that you have two fans, one totally covering each side of the vents and use proper car fans, or even motorbike ones which might be lower profile.
- Diesel Destroyer
Posted 11 years 5 months ago #116601I hear what you are saying about car/bike fans at high level.. But running ITBs I might be limited for room.. so might have to fit fans into the boot lid..
- philljoynes
Replied by philljoynes on topic Re: Engine bay cooling mods... options/ideas
Posted 11 years 5 months ago #116607Not sure if this applies here as much, but thought I would thow it out there.
- Diesel Destroyer
Replied by andy1970h on topic Engine bay cooling mods... options/ideas
Posted 11 years 5 months ago #116616Diesel Destroyer wrote: The quad bike fans are a cracking idea..
Even from a PC cooling standpoint 40mm fans are only used when absolutely necessary and they are stupidly noisy. 1U servers have to use them as there's no headroom for anything bigger. If you want real CFM then look at at least 80mm. Compare the CFM for one of these
