front sub frame mount?
- Diesel Destroyer
You can buy new steel.. or new stainless steel ones..
I went with steel.. and slid 3.4mm CDS tube inside and puddle welded.. to beef them up.. then fitted plastic caps the bung up the ends..
Id also fit all new bolts whilst you at it.. (but that's just me)
- Fatbaldingoldgit
- Diesel Destroyer
They are solid mounts..
VHS do them.. as do MGFnTF Bitz
- Diesel Destroyer
Mind you, it has to be better than the rusty ones.
Mine were showing signs of a little surface corrosion. :woowoo:
So I bought the MS uprated ones and had them powder coated.
Same for the bottom wishbones.
Regards
Chris
