MG TF Coolant..!!??
- a Guest
- Visitor
37,000 miles.
Checking the car over today, I found a scum on top of the coolant in the expansion tank - almost like cream. The coolant underneath this scum is orange and very clear.
The engine oil is still very clear and clean(changed about 6 months ago).
I hope this isnt the start of the dreaded Head Gasket Failure.
Any ideas?
if so it could just be remnants from that.
Any other symptoms?
I wouldn't panic yet, just keep an eye on it.
- a Guest
- Visitor
gazsuttonuk wrote: No, not had a new head gasket..Ive owned it from new(2003)
thats very cool, wish i had owned bucephalus from new
i'd say fit a low coolant alarm if you havent allready done so and keep an eye on it
new cap may not go amiss or clean up the old one
- adamelphick
- Rich in Vancouver
Rich in Vancouver wrote: There is a kit available, from Frost I think, that will detect the by-products of combustion in the coolant and give you an indication if the head gasket is on it's way out.
That's right. Usually called a 'sniff test'.
I think most garages would be able to do this for you. That's how I confirmed my HGF, but I was getting symptoms of the expansion tank filling up with coolant when the engine was up to temperature, so I was pretty sure I was getting gases into the coolant anyway.
- a Guest
- Visitor
Adam, Ive alredy fitted a low coolant alarm a couple of years ago, and dont take my eyes off the temp gauge.adam-mgtf wrote:
New cap might be a good idea.
Cheers.
- a Guest
- Visitor
The coolant was replaced about two years ago(and Ive not had to top it up in that time), same time as I did the big service(cam belt, adjuster, water pump) and fitted stainless steel coolant pipes.adamelphick wrote: Fingers crossed it's not HGF mayo - another possibility is that you have topped up with the wrong antifreeze recently? OAT and Ethylene Glycol are usually 'pink/orange' and 'green/blue' respectively - BUT sometimes they can come in the opposite colour apparently, and if accidentally mixed they cause a sludge to form.
Last night I removed some of this scum and the coolant looked sparkling and clear(orange)
Every thing is working as it should:- temperatures steady and heater working perfectly.
Its had no long runs recently, only travelling to work(10 miles) most days.
- bryan young
David A does not agree with this, he did a test mixing the two types together and nothing happened to form sludge, mind you it may need to be heated an mixed with a bit of oil and combustion gasses :whistle:
- adamelphick
Ooh maybe where I googled it from was talking total twaddle then!
