MGF Towbar
MGF Towbar was created by p24hrsmith
Posted 11 years 6 months ago #122195
I always thought that MGF's where not allowed to tow because MG said they where unsuitable for towing and so you would be breaking construction and usage rules.
However I have just read this is not the case for models manufactured from 95<98 its legal for them to have a towbar which you can get from a company called Watling Engineers http://www.watling-towbars.co.uk/uk_cars.html and I have also found one on Ebay
Watling Flange towbar M.G. MGF Convertible 95 To 98
Completed
I have emailed Watling Engineers and asked if they can tell me why this is but I'm some of you clever people out there already know.
Last Edit:11 years 6 months ago by p24hrsmith
Last edit: 11 years 6 months ago by p24hrsmith.
Replied by p24hrsmith on topic MGF Towbar
Posted 11 years 6 months ago #122196
Oh spit I can't see ebay thing and I can't seem to see anyone else's ether so here is link just incase
Completed
Replied by Whiz on topic MGF Towbar
Posted 11 years 6 months ago #122199
OOh interesting!
I didnt think we were allowed to tow either...
I wouldnt get a bar though, just lash a caravan to my spoiler :)
by Whiz
The following user(s) said Thank You: tim-mgf
Replied by helsbyman on topic MGF Towbar
Posted 11 years 6 months ago #122200
I would have thought a tow bar would be ok so long as you don't tow more than 60-80 KG extra but as with all things one ends up towing 100-150 KGS
Replied by Blow-in on topic MGF Towbar
Posted 11 years 6 months ago #122211
Must be an age related type approval loop hole. I wouldn't have though that you could tow much with an MG F as it's a light car...there would also be a fairly low towball weight limit...the F has non height adjustable headlights on the assumption that you won't put too much weight in the boot so having a towbar with some down force is putting weight in all the wrong places (consider also some of the rear shock mounting failures we are seeing). Having said all that I fitted a Watling Engineers front tow bar to the 4x4 and it's a solid product.
Richard
by Blow-in
Replied by David Aiketgate on topic MGF Towbar
Posted 11 years 6 months ago #122216
The towing question is fraught with MG forum urban myths.
In fact the only mention about towing the car that I've found in official literature is an admonition not to tow the car with a rope or chain. This is for the simple reason that a rope/chain would damage the front of the car because the eyes are really low on the subframe.
Towing the car with a dolley, A frame or a bar is OK.
In law, only a vehicle with a Gross Train Weight stamped on the vin plate SHOULD tow a trailer in the UK. This is the maximum weight of car and trailer combined.
I think in reality that you'll find a lot of cars towing caravans which don't have the required vin stamp. So the MGF/TF is like a lot of cars it doesn't fulfill the legal requirement to allow you to tow a trailer.
This is a useful page
Last Edit:11 years 6 months ago by David Aiketgate
Last edit: 11 years 6 months ago by David Aiketgate.
Replied by Andy Lawrence on topic MGF Towbar
Posted 11 years 6 months ago #122224
This is cool.
WHALE OIL BEEF HOOKED
Posted 11 years 6 months ago #122231
Got reply from Watling Engineers.
Thank you for your inquiry. European legislation which applies to vehicles
registered in this country from 1st August 1998, requires that towbars are
type approved (tested) and ours is not. This is why it can legally be used
for towing for earlier vehicles and not later ones. The main issue is with
insurance. If, however you were only to use it to carry bikes, for
instance, as this is not towing the legislation does not apply.
As far as I can find out just because MG/Rover say the F is not suitable for towing doesn't mean you can't it means what it says. However as W.E say its insurance companies that will most likely object on those grounds.
Mind you being able to bolt a bike rack on could be useful
Posted 11 years 6 months ago #122233
some pic's I have found
Replied by Cobber on topic MGF Towbar
Posted 11 years 6 months ago #122263
p24hrsmith wrote: Mind you being able to bolt a bike rack on could be useful
For what.....taking bikes to the tip where they belong?????? :lol:
The following user(s) said Thank You: Smutmeister
Replied by talkingcars on topic MGF Towbar
Posted 11 years 6 months ago #122270
MGR said not to tow with the F because it would stretch the central part of the body, that tow bar gets around this by connecting to both subframes.
Personally I wouldn't want to tow much more than nothing in an F but then I can tow 44 tonnes!
Replied by cjmillsnun on topic MGF Towbar
Posted 11 years 6 months ago #122281
Not sure I like that towbar anyway. The ground clearance is low enough without an inch of box section below the subframe. Would not be fun on the speed bumps.
Time to create page: 2.028 seconds
