clutch problem
can anyone help,wilst out clutch pedal went to floor had to drive home without clutch. diagnosed as faulty master cyl, new cylinder fitted bled with pressure bleeder pedal great put all tools away refitted all covers etc started up to go out no clutch!!!!!! pedal almost to floor? any ideas, could it be damper next to m/cyl? thanks phil
by rio100
I had troubled with clutch bleeding once. Got some advice from here and it was air in the master cylinder, had to bleed it at the top of the master cylinder where the pipe is screwed in. Hope that helps.
[IMG]ht[/img]
by Davem
The following user(s) said Thank You: Leigh Ping, rio100
:welcome2:
As I wrote in the shoutbox, you need to check the level of fluid in the master cylinder if it is still full, then I suspect you have air still in the system.
If the level has dropped you probably have a leak somewhere and the likely culprit would be the slave cylinder.
The following user(s) said Thank You: rio100
Time to create page: 0.459 seconds
