hood problem 2 years 1 month ago #198829
I've got the common problem of the hood jamming and know to pull the second hoop to assist it, so today I when I came back and put the hood up I thought take a look. It appears I already have the elastic assister straps fitted (I didn't know) and I suspect they need tightening as they are at the beginning of their range, do you do it with the hood up or done and how tight should they be?
hood problem 2 years 1 month ago #198830
Down and tight enough to collapse the hood. It is no more difficult than that. I had a pair made from elastic and Velcro for a couple of quid and they work just fine.
The following user(s) said Thank You: Leigh Ping, deepfat
hood problem 2 years 1 month ago #198832
Thanks for that, I thought of elastic with velcro but that was before I looked, I don't think in the 9 months I've owned it I ever looked closely at the underside of the hood.
hood problem 2 years 1 month ago #198834
Dont forget to give the mechanism hinges a quick lube with lithium grease. If you use the spray can, just watch for over-spray...
Rubber seals will also benifit from a liberal application of " gummi Pfledge " to restore the softness to the seals.
hood problem 2 years 1 month ago #198842
Thanks GORSQ if that stuff works I will use it on all my rubbers (stop sniggering) interesting product name doesn't exactly roll of the tongue like "Rubber Reviver" would.
Fixed the tensioner thingy, I think there are various types but on mine the loops in the buckle are stitched in I only found this out after trying unsuccessfully to shorten it like a belt buckle. I just ignored the loops shortened it a bit, fed it back thru the buckle and put the pin back, fiddly but doable. Minimax's idea of using velcro to hold the elastic would make it much simpler to adjust if needed.
hood problem 2 years 1 month ago #198844
I bought a yard of 2" black elastic and 2' of 2" black Velcro. Cut the elastic in two and folded the halves to make a 9" doubled layer then had the Velcro sewed onto the ends, hooks up, loops down and cut the Velcro to a convenient length on installation. Cheap and very effective.
hood problem 2 years 1 month ago #198847
Thanks I'm going to have a go at that as I happen to have a length of 2" velcro knocking about somewhere so only need the elastic
Time to create page: 0.094 seconds
