Hello I went to the car today,to bleed the recon front caliper but I am unable to get any fluid out of the bleed nipple .I removed the pipe from the caliper and nothing pours or drips out of it,when pressing the brake pedal . I think being an old pipe,when I had it clamped it hasnt recovered and is now blocked .So it wouldnt harm to replace it anyway I will still check how clear it is Ive always found,when you take the pipe off the caliper brake fluid always come out of it .Start one job and another pops up Len
If you choose to use Braide hoses rather than OEM, beware the hose "winding-up" as you tighten the Banjo. There is no anti-rotation/locating "Lug" on the Braided hose. One side of the car (Cannot remember which) the hose WILL tend to move to the wrong position, where suspension & steering movement might put the hose under tension. Pictures of the wire restraint I made, to hold the braided hose in the "Right position is attached.
ALSO: I do NOT like the stainless steel banjo bolts Goodrich & probably other suppliers use. The cross hole goes right through (Only 1 side on OEM) thus reducing strength on what is almost certainly a lower tensile strength (stainless) stell, versus standard plated High-tensile steel. One of my stainless-steel banjos was sheared. See picture at end.
I have replaced all with normal banjos.
