Door mirrors - How to dismantle, replace glass.
Door mirrors - How to dismantle, replace glass. was created by David Aiketgate
Posted 14 years 4 months ago #14826
I needed to dismantle the offside mirror as a passing car had damaged the black surround and cracked the glass.
As a temporary measure I obtained a replacement glass from Halfords. It simply stuck on top of the damaged original
However as a permanent fix I obtained a replacement mirror complete from Rimmer Bros. for a very reasonable £20.
And this is how I replaced the black surround and mirror glass.
If you need to get into the mirrors, they come apart quite easily.
The black surround detaches from the painted section by the careful use of a thin blade or screwdriver. Push the black surround down and out, to unclip it.
If you pull the glass equally from each end, it simply pulls off its cradle, leaving only the two electrical connections for the heating element to disconnect to remove the glass completely.
Then I simply replaced the damaged surround and glass with the equivalent pieces from the new mirror, by connecting the electrics, then locating the four prongs on the new glass into the cradle and pushing it to snap into place.
The surround is similarly located and snaps back into place by pressing around the perimeter.
Glass Replacement
If you just need to replace the glass, there is an easier method.
If you push the glass in at the inner side so you can get your finger ends around the  outer edge.
You should be able to get the glass to release from its cradle by pulling
If it is unwilling to release then, if you look within the mirror you will see a bare metal plate.
Use one finger to push that metal plate back as you pull the glass outwards.
The glass will release from the cradle, you will then need to undo the two electrical clips mentioned above to remove the glass completely.
Then to fit your new mirror glass you just need to connect the two heater wires, locate the new glass by the little prongs in the cradle and push firmly back into place.
If anyone needs a Nightfire Red door mirror, with a slightly damaged surround and a stuck on glass, I have one.:yesnod:
Last Edit:3 months 2 weeks ago by David Aiketgate
Last edit: 3 months 2 weeks ago by David Aiketgate. Reason: Clarity and new pics
The following user(s) said Thank You: Leigh Ping, richandpaula
Replied by g4wam on topic wing mirror motor
Posted 14 years 3 months ago #15792
david,
just seen this excellent article and wondered if I could get access to my motor using this method of dismantling?
The passeneger side wing mirror adjustment motor is not moving as well as the driver side and it may be possible to see what is wrong
thanks
Mike
by g4wam
Replied by David Aiketgate on topic Door mirrors - How to dismantle, replace glass.
Posted 14 years 3 months ago #15793
g4wam;15792 wrote: david,
thanks
Mike
Yes Mike,You can see the motor in this photo:-
Last edit: 3 months 2 weeks ago by David Aiketgate. Reason: Inserted pic
Replied by g4wam on topic Door mirrors - How to dismantle, replace glass.
Posted 14 years 3 months ago #15837
David,
thanks-I will let you know if I find out what is wrong with my motor on the passeneger side.
Mike
by g4wam
Replied by tjackson on topic Re: Door mirrors - How to dismantle, replace glass.
Posted 12 years 3 months ago #65497
Fix the mirror carefully cut the black plastic surround from the glass and after that replace the glass.
Replied by richandpaula on topic Door mirrors - How to dismantle, replace glass.
Posted 9 years 2 months ago #162728
Great 'How To' David - thank you. :)
Posted 9 years 2 months ago #162837
Door mirror glass now replaced. It took me 5 minutes tops. Thanks again for the 'How To' David. :)
Posted 3 months 2 weeks ago #208273
Added new photos to this how to.
Time to create page: 0.535 seconds
