Soft top; Rear Foam Seal - How to Replace.
Soft top; Rear Foam Seal - How to Replace. was created by David Aiketgate
Posted 14 years 1 month ago #17689
When I lifted the rear of the hood I was reminded what a sad state the foam seal was in! Disgusting!
Last Edit:14 years 1 month ago by David Aiketgate
Last edit: 14 years 1 month ago by David Aiketgate.
Replied by David Aiketgate on topic Re: Hood Foam Seal - How to Replace.
Posted 14 years 1 month ago #17690
I decided to replace this mess, but didn't want to use the same material as I thought it would deteriorate in a similar manner. I found some VELCRO in the local DIY store (the packaging was damaged and it was going cheap!)and so I thought that the loop side would be perfect to replace the foam seal.
Posted 14 years 1 month ago #17691
The first thing was to remove the old seal. I used a chisel to scrape the remnants off the metal.
You will be left with the adhesive to remove, and I used some spray adhesive remover to clean it off, Leaving you with this.
Posted 14 years 1 month ago #17692
I rubbed the metalwork down and sprayed it with black paint, to tidy it up.
The following user(s) said Thank You: Leigh Ping, BigPhil
Posted 14 years 1 month ago #17693
When the paint had dried, I applied a coating of contact adhesive to the metal.
When the adhesive was tacky I began to apply the velcro tape.
Posted 14 years 1 month ago #17694
Definitely an improvement, and I hope the velcro will last better than the original foam.
The following user(s) said Thank You: Leigh Ping, pacer
Replied by Leigh Ping on topic Re: Soft top; Rear Foam Seal - How to Replace.
Posted 12 years 9 months ago #41014
Last Edit:10 years 9 months ago by Leigh Ping
Last edit: 10 years 9 months ago by Raccoon.
Replied by Petesmgf on topic Re: Soft top; Rear Foam Seal - How to Replace.
Posted 12 years 9 months ago #41015
Well I wish I knew about the T Bar 12 months ago when I replaced the seal on my soft top.
Bought the replacement foam from Rimmers & was hellish expensive for what it is.
Soon after found a similar product in ScrewFix for a fraction of the cost
As they say hind sight is a wonderful thing, lesson learnt - dont just jump in until researched the subject.
Replied by Keymaster on topic Soft top; Rear Foam Seal - How to Replace.
Posted 8 years 1 week ago #174275
This is on my list of jobs to do when I get a dry spell of weather. I have been looking for a suitable alternative to the foam strip and wandered if the Velcro has stood up to the test of time seeing that David had originally installed it over six years ago.
Replied by David Aiketgate on topic Soft top; Rear Foam Seal - How to Replace.
Posted 8 years 1 week ago #174277
It's still as good as the day I fitted it. :yesnod:
The following user(s) said Thank You: COMMANDER, Keymaster
Posted 8 years 1 week ago #174339
That's great David, Thank you. Definitely an improvement on foam rubber. I will get enough for both the Tf and the F, better not do one and not the other. :clap:
Replied by kdupke on topic Soft top; Rear Foam Seal - How to Replace.
Posted 7 years 11 months ago #174885
What I have used some years ago is some self-expanding (but compressed delivered) band of foam as used for buildings (like seal a window). This is available in various sizes, the thinnest is 1-3mm thick (1compressed, 3expanded).
Please make sure you open the 'wheel' with the band just shortly before using, or it will be already expanded.
regards,
kai
by kdupke
The following user(s) said Thank You: talkingcars, Keymaster
Time to create page: 0.796 seconds
