Air throughflow vents - How to improve
Air throughflow vents - How to improve was created by David Aiketgate
Posted 13 years 10 months ago #64625Looking at the external air box it's easy to see why.
The only access for air is hidden away in here, with a metal cap over it (to stop rain entering the heater.)
An easy way, I thought, to increase airflow would be to open another access hole and direct air from the front of the car into it via a flexible pipe.
The box is made of thin plastic and using one of these,
it is easy to open a hole.
- a Guest
- User
Replied by a Guest on topic Re: Air throughflow vents - How to improve
Posted 13 years 10 months ago #64627Some people have removed the box altogether to get more room in the front :dry:
Replied by bensewell on topic Re: Air throughflow vents - How to improve
Posted 13 years 10 months ago #64628Please Log in or Create an account to join the conversation.
Replied by David Aiketgate on topic Re: Air throughflow vents - How to improve
Posted 13 years 10 months ago #64630Replacing the black cover covers this all up and nothing can be seen.
A quick test drive confirmed that the air flow was increased. initially I have just fed the hose into the wheel arch area, but I may reroute it to get a more direct flow.
Posted 13 years 10 months ago #64632Yes but it is also the source for all vented air in the car. Hot or cold.bongodave wrote: Excuse my daftness here, but isn't this the vent for the internal heater?
- a Guest
- User
Posted 13 years 10 months ago #64635Please Log in or Create an account to join the conversation.
Posted 13 years 10 months ago #64637David
- Leigh Ping
Online
Replied by Leigh Ping on topic Re: Air throughflow vents - How to improve
Posted 13 years 10 months ago #64647Please Log in or Create an account to join the conversation.
- Leigh Ping
Online
Posted 13 years 10 months ago #64656David has solved that problem with this cleverly thought out air mod.
Posted 13 years 10 months ago #65888This has been a great success, improving the flow of air into the cabin. Overcoming that stuffy feeling if you're forced to have the roof up in inclement weather conditions.
I have now re-routed the hose so that the opening is facing forward to receive maximum air flow. It is actually positioned where the anti-roll bar meets the subframe.
This has increased the flow substantially through the vents/heater system.
If necessary (if it's cold and the heater hasn't warmed up yet, for example) all the flow can be diverted to the demister vents.
Unfortunately, I need to go back to Italy to really test the new set up.
Replied by PQD44 on topic Re: Air throughflow vents - How to improve
Posted 13 years 10 months ago #65892Nice mod I too like plenty of fresh air when forced to drive with the hood up. Thanks for the update David
Between you and Leigh shares in vacuum cleaner hose manufacturers are on the increase, well done guys.
Posted 13 years 10 months ago #65896I had to do something with all the hose from my failed airscarf.
