Compliance washers - What's that about then?
Compliance washers - What's that about then? was created by David Aiketgate
Posted 11 years 6 months ago #118233If you look at this area at the rear of the MGF.
Pointy Man
The big bush gets worn and you can end up with this.
A close up showing the gap.
OK, but so what? Well that gap means that the wheel can move back and forwards in relation to the subframe. This means that you get a worrying effect of rear wheel torque steer.
In English, the car will pull to one side on acceleration and pull the other way when you lift off.
So if your car is exhibiting this, check the gaps where the Pointy man is indicating!:lol:
You can replace the bush with OEM or with a poly bush. You can also use compliance washers to take up the gap to remove the rear steering!
AdamElphick has produced a very good 'How to' where he completely dis-assembled the bush.
Here is how you can do it without taking the car to bits.
You'll need washers made to the same dimensions as Adam's. I used a handy piece of material that is only 1.5mm thick, so I needed two washers each side of the bush. To enable the front ones to fit, simply cut a section out of the washers. Here's Dave (Tatts) producing the washers for his own car.
And here's a full set for one side.
Now it is just a case of removing the 18mm nut and shaped washer from the end of the shaft. Obviously safety rules apply, and axle stands are in evidence.
You can now insert the cut washers at the front. Ensure that the cuts are offset from each other if using two washers.
And the whole washers at the rear, refit the washer and nut.
Now tighten the nut, and lower the car to the ground. With the suspension under the weight of the car, now loosen the nut off again and torque the nut to 100Nm.
- Andy Lawrence
Replied by Andy Lawrence on topic Compliance washers - What's that about then?
Posted 11 years 6 months ago #118234What's the diameter of the plastic washer???
WHALE OIL BEEF HOOKED
Replied by David Aiketgate on topic Compliance washers - What's that about then?
Posted 11 years 6 months ago #118236David
Replied by birks on topic Compliance washers - What's that about then?
Posted 11 years 6 months ago #118246Please Log in or Create an account to join the conversation.
- adamelphick
Replied by adamelphick on topic Compliance washers - What's that about then?
Posted 11 years 6 months ago #118257Please Log in or Create an account to join the conversation.
- bryan young
Replied by bryan young on topic Compliance washers - What's that about then?
Posted 11 years 6 months ago #118262Please Log in or Create an account to join the conversation.
- John and Sue
Replied by John and Sue on topic Compliance washers - What's that about then?
Posted 11 years 6 months ago #118265Or buy a TF with proper suspension....
:coat:
Replied by Tibs on topic Compliance washers - What's that about then?
Posted 11 years 5 months ago #121741I can't see a way of getting to the front smaller end of the tie rod, do you have to drop the rear end of the rear subframe to get it undone ?
- Diesel Destroyer
Replied by Diesel Destroyer on topic Compliance washers - What's that about then?
Posted 11 years 5 months ago #121742As above I'd opt for cutting a slot in the washer.. Much much quicker and less hassle
Posted 7 years 3 months ago #179738The rear end of the car is still stable so this cheap fix is very effective and long lasting.
I just noticed the agricultural fibreglass in this photo!:oops:
That is, cow muck and straw...:bust:
Replied by NigelOBB on topic Re:Compliance washers - What's that about then?
Posted 6 years 5 months ago #186390Sent from my iPhone using Tapatalk
Replied by G0RSQ on topic Re:Compliance washers - What's that about then?
Posted 6 years 5 months ago #186397From your profile picture, you have a TF (forgive me if it is for a different car ) but the compliance washers are only relevent to MG F!
TF has completely different rear suspension!
