Windscreen Washers
Thanks
- Leigh Ping
Online
- adamelphick
Sent from my GT-I9195 using Tapatalk
(but I assumed it's the same part as used by Peugeot and Citroen...
) Please Log in or Create an account to join the conversation.
Beth557 wrote: Help! My washers have stopped working this morn, I've just been out to investigate a little and I'm hoping it may be a blockage somewhere BUT, can anyone tell me if you can hear the washer motor buzzing when operating them and sat in the car? I couldn't hear anything with the bonnet open which I suppose is a bad sign...
Thanks
You should definably hear them if you were outside the car with the bonnet open. When I first got my car I found the washer pump connection had corroded badly and the pump had also died.
- adamelphick
Bertl wrote: have also the Fiat ones, works perfectly!
(but I assumed it's the same part as used by Peugeot and Citroen...)
What ones are the fabled Fiat ones?
