Liquid levers suspension pump with vacuum facility
Replied by minimax on topic Liquid levers suspension pump with vacuum facility
Posted 4 years 3 months ago #198825
Verofan: the ride height at the rear is not measured because it is controlled by the height at the front which is the datum this should be 368mm from wheel centre to bottom of arch measured vertically. Wheels straight ahead and two hours after a spirited run, handbrake off and on level ground like a multi storey car park. Tolerance plus or minus 10mm. Anecdotally about 360mm is the favoured setting on standard cars. This at 17 Celsius, add 0.45 mm for each degree above and subtract likewise for lower temperatures.
by minimax
Time to create page: 0.361 seconds
