Broken plastic rear screen
i was just wondering if anyone has a broken plastic rear screen that they no longer need? it needs to be the sort with the zip all the way around, rather than the type with velcro down both sides.
i am considering getting some rear screen plastic and trying to replace DIY using the old dears sewing machine and some heavy duty needles / thread. if it goes easy enough, i might be able to offer a limited service of replacing the screens on the cheap, possibly for cost + a site donation? :broon: i wouldn't be able to promise a fast turnaround though :lol:
anyway, first things first, does anyone have one they don't need?
many thanks,
Lee
Pete Vickerstaff
MG F/TF Central
- your one stop shop for MGF/TF tips, tricks, faq's, how to's and links
the hood i got from Jan has a zip along the top edge, and velcro down each side. MK1?? any advice welcome :broon: i would go and check again, but it's p ing it down at the moment :lol:
Incidentally this change (mk1 to 2 zip ) happened well before the car change mk1 to 2.
I don't know what you have got?
- Mr Forgetful
Sorry to have to correct you David, a MAJORITY of Mk1 cars had the later 97 - 05 8mm Opti zip. A few early cars had a narrow (7mm) Opti zip, some had a similar YKK zip but most had the later zip.David Aiketgate wrote: As Pete says, all standard roofs have the top zip and velcro sides. The only difference between mk1 and 2 is the zip quality. Meaning that you need both sides of the zip to swap between mk1 and 2.
Had to change the hood side of a 7mm Opti on Monday!
As for the zip which ran up the side, over the top and down the other side: Aftermarket hood of unknown manufacturer, have replaced several of them, but have disposed of them so cannot offer the OP a solution other than a complete hood replacement?
groovylee wrote: Hi all,
many thanks,
Lee
Also, he's after a rear screen with just the top zip, so I might be able to help him out
Cheers all
Lee
