foglamp brackets
- mgtfbluestreak
..................... :beer:
However they do command a good price, and expect to pay between £30 and £60 for a pair!
The brackets are glued to the bumpar with some wonder-glue, so removing from a used bumper usually damages the brackets unless you are very patient and careful!
Usually better, and cheaper to find a used bumper with fogs already fitted.
Of course nothing to stop you fibre-glassing them into your bumper though!
Peter
- mgtfbluestreak
Does this mean then that some later models may have the wiring in place? ...................I checked ebay at the time of writing this post and found 1 bracket for sale..........the bumper has 6 drillings to except screws for the bracket which ive highlighted with yellow arrows so I assume the later brackets screw on apposed to the older types being glued............................ :bust:
yeh there pricey :dry:
how much :slapme: :slapme:
- adamelphick
- mgtfbluestreak
- adamelphick
mgtfbluestreak wrote: just been reading bobs how to on fitting spotlights..........................very useful,after reading it im now confident to wire my own fogs................just need to locate,2 brckets,relay and switch :woohoo:
I got most of the stuff from mgfntfbitz give them a call I'm sure they will have everything you need apart from the brackets.
I have the two fog light connectors if you need them and I have a pair of brackets as well, but they are the glue on type.You're welcome to everything for the price of postage. I can post a picture of the brackets if you like they would need a little work to bond them on.
Edit. B&G do the brackets for around £40 here's a link http://www.ukmgparts.com/product/mgf14-exterior-bodyshell-panels/tf-frt-fog-bracket-lh-622376-dpl000190
http://www.ukmgparts.com/product/mgf14-exterior-bodyshell-panels/tf-frt-fog-bracket-rh-622376-dpl000180
- The driving dutchman
- mgtfbluestreak
I to want to fit fogs to my car just because there more pleasing to look at then black plastic covers but no way would I pay 60 quid for 2 small bits of plastic id rather fabricate some mounts .. no ones goin to see them so personally I dont think it matters as long as its up to the job , sturdy and safe
No need to pay £60 the screw in ones are £40ish at Brown and Gammons.
