Re:Re:Re:Ring/bezel for N/S fog light for MGF
- SALAD DODGER
- Novice MGer
Ring/bezel for N/S fog light for MGF was created by SALAD DODGER
Posted 3 years 3 months ago #201708I have a picture of the one on the other side for reference. Any colour will do. Thanks.
Replied by Raccoon on topic Ring/bezel for N/S fog light for MGF
Posted 3 years 3 months ago #201710Seems not to be available from the usual suspects, fingers crossed you find a good used part!
- SALAD DODGER
- Novice MGer
Replied by SALAD DODGER on topic Ring/bezel for N/S fog light for MGF
Posted 3 years 3 months ago #201711Please Log in or Create an account to join the conversation.
Replied by Airportable on topic Ring/bezel for N/S fog light for MGF
Posted 3 years 3 months ago #201717Best of luck.
- SALAD DODGER
- Novice MGer
Posted 3 years 3 months ago #201719Please Log in or Create an account to join the conversation.
- ashleyfrazer
- Apprentice MGer
Replied by ashleyfrazer on topic Re:Ring/bezel for N/S fog light for MGF
Posted 3 years 2 months ago #201849Could someone scan these increasingly hard to find parts and 3D print? Ash
Sent from my SM-S908B using Tapatalk
Replied by Cobber on topic Re:Ring/bezel for N/S fog light for MGF
Posted 3 years 2 months ago #201852Hi
These and the fog light mounts are the sort of parts that are made of unobtainium, but would be easy to 3D scan and print.
The other thing that would be handy for fitting these would be a copy of the fitting instructions, the cutting template in particular.
Though I suspect all of those would’ve been thrown out or fallen to bits long ago.
Salad Dodger, you could take the one from the other side and have it 3D scanned, then they can flip it over on the computer to give the correct coordinates for the opposite side then they can 3D print that.
Replied by Roverlike on topic Re:Ring/bezel for N/S fog light for MGF
Posted 3 years 2 months ago #201853The other thing that would be handy for fitting these would be a copy of the fitting instructions, the cutting template in particular.
I do not know if you had a chance to look at this thread: https://www.the-t-bar.com/forum/roverlike-s-guides/97883-mg-f-tf-front-fogs-parts-wiring-diagram-installation-guides
- SALAD DODGER
- Novice MGer
Replied by SALAD DODGER on topic Re:Ring/bezel for N/S fog light for MGF
Posted 3 years 2 months ago #201854
Hi
I did actually find someone who has indeed 3D printed these fog light trim rings but they sell them for around £35 each which I think is a bit expensive though I doubt they sell many of them due to there not being many cars that actually have them fitted. If you look at it in the way that some buyers would need two of them, it does make it a bit of an outlay for many owners. I had a hard job to even find a replacement fog light. Even when I found one it wasn't the same as mine. It required a different bulb so I changed the connection plug to suit.
This is the link for the 3D printed rings: [email protected]
- ashleyfrazer
- Apprentice MGer
Replied by ashleyfrazer on topic Re:Re:Ring/bezel for N/S fog light for MGF
Posted 3 years 2 months ago #201857When my fog lights were fitted the rings wouldn't sit flush. I painted them with a rattle can but the paint chipped off on the roads of Norway. I decided to have it painted professionally. I added a splitter which has the fog light surround built in. (The splitter needs painting again after it was damaged getting it off a load loader - happening soon I hope)
The splitter is available to order but you need a long sit down when you see the price! £70 for a pair of rings looks cheap. It is an alternative though. Search "mgf front splitter m100"
Ash
- SALAD DODGER
- Novice MGer
Replied by SALAD DODGER on topic Re:Re:Ring/bezel for N/S fog light for MGF
Posted 3 years 2 months ago #201859We have owned this MGF for a long time now and its just sod's law that ours has fog lights that most other MGFs don't have.
I'll find one in the end. It just take's time.
- ashleyfrazer
- Apprentice MGer
Replied by ashleyfrazer on topic Re:Re:Re:Ring/bezel for N/S fog light for MGF
Posted 3 years 2 months ago #201860What I meant was £70 is expensive but the splitter like mine is £200! I am sure I paid about half that.
I guess you could remove the fog lights, sell off the kit and buy a used front bumper with no holes in it. It will change the face and if you have had it a long time changing its face might not be palletable.
Take care
Ash
