Change MGF side lights/Upgrade to LED's
Change MGF side lights/Upgrade to LED's was created by Sanchez
Posted 13 years 8 months ago #83063
Part 1.
I recently changed my side lights to LED's and the only how too was for the TF. So i thought id do the F how too! It's much more simple and no tools are required.
Step 1 - Open the front bonnet/spare wheel compartment.
Step 2 - Identify the bulb cover and turn it to the left (Lefty Loosey).
Step 3 - Pull the cover off and place to one side.
Step 4 - Identify the side light housing.
Step 5 - The side light housing is held i place by friction. Grip hold of the white portion and pull with a wiggle to free it.
Step 6 - Remove the old bulb by simply pulling it out (the bulb is held in by friction)
Step 7 - Fit the new bulb/LED (in my case LED) by just pushing it in.
Step 8 - Replace the side light housing by pushing it back into the hole it came from.
To be continued... can only add 8 pics at a time lol!
Last Edit:13 years 8 months ago by Sanchez
Last edit: 13 years 8 months ago by Sanchez.
Replied by Sanchez on topic Re: Chang MGF side lights/Upgrade to LED's
Posted 13 years 8 months ago #83065
Part 2.
Step 9 - Replace the bulb cover by placing it back on and turning it to the right.
Step 10 - Switch the side lights on and check the bulb/LED works. Repeat on other headlight cluster. Done!
Enjoy your new side lights!
by Sanchez
Replied by paulsmgf on topic Re: Chang MGF side lights/Upgrade to LED's
Posted 13 years 8 months ago #83067
A good write up sanchez well done you :broon:
The following user(s) said Thank You: Sanchez
Replied by a Guest on topic Re: Chang MGF side lights/Upgrade to LED's
Posted 13 years 8 months ago #83078
Brilliant 'How to' Sanchez.. :broon:
I did exactly the same to my MG TF and two MG ZR's, used exactly the same led bulbs..they have been in just two months and they have either stopped working altogether or are flashing...had to refit the originals...
I hope yours last longer.
Replied by Leigh Ping on topic Re: Change MGF side lights/Upgrade to LED's
Posted 13 years 6 months ago #94891
Tibs wrote: Did you get your 360 bulbs in the end and are they any good ?
These are good Tibs and close by to you in Birmingham too. :yesnod:
Great how to guide Sanchez. Now added to the how to lighting list. :broon:
Sidelight Bulb Changing Guide number 1 by Sanchez. - MGF Sidelight change and upgrade guide 1 - LED x 7.
Sidelight Bulb Changing Guide number 2 by 'Blow in' Richard. - MGF Sidelight change and upgrade guide 2 - LED x 4.
Last Edit:13 years 6 months ago by Leigh Ping
Last edit: 13 years 6 months ago by Leigh Ping.
Posted 13 years 6 months ago #94900
gazsuttonuk wrote: Brilliant 'How to' Sanchez.. :broon:
Snap Gary, I have replaced mine twice now :coat:
Great how to :broon:
  • Bob
Replied by Bob on topic Change MGF side lights/Upgrade to LED's
Posted 13 years 6 months ago #94905
Nice how to Sanches well done great pictures.
I've had smd's in for the last couple of years and still on the same pair.My MOT station always moan about the light being 'a bit blue' which it is not, but next to the yellow main headlight bulbs it does look blue.Having said that he still passes my car but some testers out there may fail you with these bulbs in.
Last Edit:13 years 6 months ago by Bob
Last edit: 13 years 6 months ago by Bob.
Posted 13 years 5 months ago #101161
Mine are still working so far!!! :woohoo:
by Sanchez
Replied by bryan young on topic Re: Chang MGF side lights/Upgrade to LED's
Posted 13 years 5 months ago #101224
Great "how to" thank you. Did mine before Christmas, nice white light too.
Time to create page: 0.993 seconds
