fog lights mgf
fog lights mgf was created by sherwood0_8
Posted 13 years 5 months ago #102606
Has anyone tried using this template http://www.mgfregister.org/forum/viewtopic.php?f=8&t=10112 for the cutting of the bumper????????? I want fogs but the template are rocking horse poo!! to find
Replied by Leigh Ping on topic fog lights mgf
Posted 13 years 5 months ago #102627
Here's everything we have on lighting. I don't think we have the bit you're looking for but maybe one of the members can be of help. :yesnod:
LIGHTING
Bulb List - Bulb locations and types.
Bulb Number Plate Lights - Replacement guide.
Bulb Side Repeater - Replacement guide.
Broken MGF front indicator clip fix - Repair mod.
Headlamp - Dipped Beam Headlight Bulb Changing - Headlamp - Headlight Bulb changing - MGTF H7 55W Bulb.
Headlamp - Main Beam Headlight Bulb Changing - Headlamp - Headlight Bulb changing - MGTF HB3a 60W Bulb.
Headlights - Improvement guide.
Headlights - Trophy headlight type Painting guide.
Improving instrument display illumination - Visible light upgrade.
Instrument Cluster Warning Lights - Display guide.
Instrument Cluster - Iluminated Needles - Fitting guide.
Light and wiper stalk upgrade using Rover 800/Freelander control stalks - Fitting guide.
Lights Interior LED - Fitting guide.
Rear Lamp Protectors - Fitting guide.
Sidelight Bulb Changing Guide - MGF Sidelight change and upgrade guide.
Sidelight Bulb Changing Guide - MGTF Sidelight change and upgrade guide.
Tail light bulb upgrade - MGTF Tail light change and upgrade guide.
The following user(s) said Thank You: sherwood0_8
Time to create page: 0.404 seconds
