LED DOOR PINS
LED DOOR PINS was created by sherwood0_8
Posted 13 years 5 months ago #102638
Does any one know how I can make a set of led door pins flash when the car is locked??? can i just tap into the LED thats in the car already has any one done this????????????????
Replied by Luckymarine on topic LED DOOR PINS
Posted 13 years 5 months ago #102639
You might be able to take a feed from the side repeaters, they're not too far away, pop the lights out of the wing and then run the wires into the door from behind the wing.
Would flash when open and double flash when you locked up.
Oh and when your hazards were on! ha!
The following user(s) said Thank You: sherwood0_8
Replied by Mal7921 on topic LED DOOR PINS
Posted 13 years 5 months ago #102640
Luckymarine wrote: You might be able to take a feed from the side repeaters, they're not too far away, pop the lights out of the wing and then run the wires into the door from behind the wing.
And indicating...
by Mal7921
Posted 13 years 5 months ago #102648
It is possible to do, for each LED you would need to take a feed from the wiring for the LED in the center console. Connecting the wires and routing them through the doors so they don't snag or get caught in anything is the easy part, its the mounting of the LED's that will be hard, considering the stalks move and that movement quite sudden and comparatively "violent" when they move.
I'd recommend locktight hybrid glue, though this MUST be left for 24 hours before using in anger (kept my rear view mirror attached for the last 12 months so I highly recommend it), so the LED is less likely to fall out with continued use.
Or... Mount just ahead of the stalks through the door card, I've seen a few done like that as aftermarket mods and saves threading the wiring around the locking mechanism.
by Mal7921
Replied by mandymay1971 on topic LED DOOR PINS
Posted 13 years 5 months ago #102649
I like the look of these going to order a blue set, Just remember to get the wires out of the way so window does not catch them and cause broken wires or even a short circuit
Replied by sherwood0_8 on topic LED DOOR PINS
Posted 13 years 5 months ago #102650
has anyone had the clocks out how easy are the wires to get at to take a feed off???
Time to create page: 0.745 seconds
