How to change heater knobs / controls
How to change heater knobs / controls was created by bensewell
Posted 12 years 10 months ago #127270
Have you a noticed a desire to buy things all things that look shiny?
Didn't notice it before ?
Relax this is normal behaviour since buying your MGF / TF. :yesnod:
Fancy some new knobs but unsure what to do? :-?
Read on at your own risk seeing more bling may result in sporadic buy it now impulses and small lies needed to loved ones when parcels arrive at your door.
What you need...
A length of string and your new knobs.
Wrap the string around your old knob, loop a bit at the bottom and PULL. It should pop off easy enough.
Then get out your new shiny superior knob ( :oops: :woowoo: ) then push it on on by lining up a lug on the inside of the knob with the metal thing inside the heater controls. It feels a bit stiff when you push it on, this is usual knob behaviour :whistle: :bat:
Ooooh Look look one done 2 to go...
Continue in this fashion until all 3 are done.
Then admire your handy work and gloat / convert the people who have plastic knobs to give in to temptation and join us...
Takes around 3 mins to do this mod and the controls feel a bit stronger .
Last Edit:12 years 10 months ago by bensewell
Last edit: 12 years 10 months ago by bensewell.
Replied by Mickle5 on topic How to change heater knobs / controls
Posted 12 years 10 months ago #127271
That's a great tip, I spent ages struggling to prise mine off when I changed to a mk2 interior. Now no innuendo intended, but nice knobs Ben, where they from?
by Mickle5
Replied by bensewell on topic How to change heater knobs / controls
Posted 12 years 10 months ago #127272
Think they are from the MGF centre I bargained someone down to 20 quid posted
Replied by Baytown on topic How to change heater knobs / controls
Posted 12 years 10 months ago #127274
Great post!
Mine are worn even though the car is very low kms and a 2004! Cheap plastic crap they used.
I'm off to Ebay!
Ken
by Baytown
Replied by the singing bush on topic Re:Re: How to change heater knobs / controls
Posted 12 years 10 months ago #127278
Excellent 'tip' for changing your knobs there mate, thanks alot...
Last Edit:12 years 10 months ago by the singing bush
Last edit: 12 years 10 months ago by the singing bush.
Replied by bensewell on topic Re:Re: How to change heater knobs / controls
Posted 12 years 10 months ago #127281
I've learned from the pliers technique and trying to wedge a knife under the knob. Both resulted in cosmetic damage on other cars i've had. :)
Replied by richandpaula on topic Re:Re: How to change heater knobs / controls
Posted 12 years 10 months ago #127285
bensewell wrote: I've learned from the pliers technique and trying to wedge a knife under the knob. Both resulted in cosmetic damage on other cars i've had. :)
Timing on this is one day late...I changed my shiny knobs back to plastic ones yesterday after getting fed up of the poor fit of the shiny ones due to the grub screw idea being pants. Now why couldn't you post this a bit earlier?? :rant:
Don't look at the cosmetic damage to my shiny heater rings from levering them with the screw driver on Saturday... :oops:
:lol:
Last Edit:12 years 10 months ago by richandpaula
Last edit: 12 years 10 months ago by richandpaula.
Replied by paulsmgf on topic Re:Re: How to change heater knobs / controls
Posted 12 years 10 months ago #127292
Loving the tip with the bit of string well done Ben :woohoo:
Replied by idrawcad on topic How to change heater knobs / controls
Posted 12 years 10 months ago #127301
2 questions, is there a difference between MK2 and MK1 knobs, I have a 2001, but the knobs on ebay (cold sweat) are mainly for MK1 models. Where did you get your ali switch surround plate from Bensewell?
Regards
Chris
Replied by David Aiketgate on topic How to change heater knobs / controls
Posted 12 years 10 months ago #127314
The mk1 and 2 have different length shafts(ooh err) so are not directly interchangeable.
Posted 12 years 10 months ago #127319
idrawcad wrote: 2 questions, is there a difference between MK2 and MK1 knobs, I have a 2001, but the knobs on ebay (cold sweat) are mainly for MK1 models. Where did you get your ali switch surround plate from Bensewell?
Switch surround was £550 free with the car
Mike Satur does a non car option about twenty quid
Time to create page: 7.760 seconds
