Rear Heater switch
Rear Heater switch was created by dext924
Posted 12 years 9 months ago #129980
Hey Peeps
Sorry if this has been brought up before, I did a quick search but couldn't find the answer....
I have a rear heater switch on the way, and the obvious question is.....does it slot straight in??
Is there wiring already in the console ready to clip on to?
Again, sorry for silly and probably repeated question...
by dext924
Replied by really? on topic Rear Heater switch
Posted 12 years 9 months ago #129983
yes. you'll need the relay also.
later TF has a smaller relay style iirc, someone else will have to confirm that bit. :yesnod:
Last Edit:12 years 9 months ago by really?
Last edit: 12 years 9 months ago by really?.
Replied by Raccoon on topic Rear Heater switch
Posted 12 years 9 months ago #130013
The wiring is already there, found it under the far right blank switch.
Not sure if it's the same position in all TFs.
And you need a relay.
An aftermarket version is only £2.50 at Rimmer .
by Raccoon
Replied by helsbyman on topic Rear Heater switch
Posted 12 years 9 months ago #130015
Yes all the wiring is there just hope you got the right switch as there are 2 types 1998-2000, 2000-2005
Replied by dext924 on topic Rear Heater switch
Posted 12 years 9 months ago #130085
Thanks...wasn't aware of the rely :)
Mine is a 2003, will the one you highlighted at Rimmers Bertl do the trick??
I read it depends on the age as to which on you can use.....
by dext924
Posted 12 years 9 months ago #130188
mine is 02. Works perfectly.
by Raccoon
The following user(s) said Thank You: dext924
Posted 12 years 9 months ago #130225
Thanks....will get one ordered :)
by dext924
Time to create page: 0.565 seconds
