hardtop filling with water
Can anyone help with a solution to my hardtop filling with rainwater please.
Many thanks
Many thanks
by DRH2010
- Leigh Ping
Hi and welcome. This is what we have in the guides section. However, someone here may know more about this problem and will answer if they do. Good luck.
HARD TOP - SOFT TOP
Glass Rear Screen - Fitting guide.
Glass Rear Screen Video - Fitting guide.
Hardtop fitting and removal information - Hardtop advice.
Soft Top - Adjustment guide.
Soft Top - Cleaning advice. Lichen, Moss, Mould, Removal.
Soft Top - Rear seal replacement.
Soft Top - Removal guide.
Soft Top - Replacement guide.
Soft Top Sticking - See video solution below.
HARD TOP - SOFT TOP
Last Edit:12 years 8 months ago
by Leigh Ping
Last edit: 12 years 8 months ago by Leigh Ping.
- John and Sue
I take it you mean that water is getting into the car.
First check: snug fit at the front: adjust the front clips if required. Need to be adjusted tight to pull the top forwards.
Second check: make sure the rear is snug along the back: the clips are adjustable for tension by means of a screw on the end of the threaded portion.
Third and most likely: it's leaking past the window seals at some point. If adjusting the clips doesn't cure it, sit in the car and get someone to shine a torch around the glass/rubber seal. Any gaps will show. The window travel is adjustable: there is a 'how to' in the how to section. Clive's I think. I used it and it works.
Hope this helps.
Hope this helps.
by John and Sue
Hi John & Sue
Thanks very much for the rapid response!
The problem is actually that water is collecting in the cavity of the hardtop & sloshes around when you drive. It will trickle out by the rubber surround of the rear window but really needs a drain hole somewhere I think. The dealer had several attempts at it but only managed to scratch the paint sadly & said no one would touch it for fear of breaking the glass, but I think others must have this problem. We think it's an original MG roof b.t.w.
Kind regards
Derek
Kind regards
Derek
by DRH2010
- John and Sue
By the cavity, do you mean the space between the shell and the liner? If so, I'd suggest taking the top off and removing the headliner. Remove the front clips and ease out the plastic push pins at the rear. These are tight and may snap but Halfords stock them or I could send you a couple.
The liner is crappy composite skinned with fibre glass and won't tolerate much wetting.
Reassemble the clips and put the top back in and get a glamorous assistant to spray around with a hosepipe. You should see where the ingress is. If the side windows aren't leaking it may be tracking around the rear window seal.
Keep us posted.
Keep us posted.
by John and Sue
Last edit: 12 years 8 months ago by John and Sue.
Time to create page: 1.683 seconds
