Radio Removal
Radio Removal was created by Markw
Posted 10 years 9 months ago #140598
Hi
Ive got a '02 MG TF. Im tempted to remove the original radio and replace it with a more modern one. I cant for the life of me work out how it comes out. Has anyone got any pointers please?
by Markw
Replied by Cobber on topic Radio Removal
Posted 10 years 9 months ago #140600
Most modern head units need special tools to remove them, the tools consist of a pair of probes (they sometimes look a bit like keys) that you stick down each side of the head unit once the escutcheon (surround piece or bezel) is removed. the two probes release the pawls that hold the head unit in place an act as handles to withdraw the unit from the dash.
Some head units have a pair of small holes on each side of the face, for these the tools you use tools that look like "U" shaped bits of wire with small knobs on the end.
Once the head unit is out of the dash you can unplug the electrical connections.
Here is a pic of a selection of tools a professional installer or an audio enthusiast would use:
Last Edit:10 years 9 months ago by Cobber
Last edit: 10 years 9 months ago by Cobber.
The following user(s) said Thank You: Markw
Replied by really? on topic Radio Removal
Posted 10 years 9 months ago #140602
the factory one in the mkII F (BMW unit) has a flap on each end, pop these out and there is a tiny allen bolt, undo this and the unit slides free.
if its not oem post a pic and ill tell you which you need. :yesnod:
by really?
Replied by Markw on topic Radio Removal
Posted 10 years 9 months ago #140603
Thanks both - looks like I will have to sport the cash to get someone to do it for me as I havent got those tools.
It seems to me to be the original OEM one. Dont get me wrong it works fine - just that I thought an upgrade would be good.
by Markw
Posted 10 years 9 months ago #140608
some units have a slot on each side - this doesnt require tools, a slice of credit card or similar will work.
ebay and others sell tool packs for head units for not much. or maybe someone might be nearby you who could help?
by really?
Posted 10 years 9 months ago #140609
If you can identify the make and model of the head unit, you can buy the tools to suit it for loose change, have search on ebay.
Or maybe someone on here might have the tools to help you out, they may've got a set so as they remove the old unit in their car to upgrade it and they don't need the tools anymore.
I have a full set of them, and I'd me more than happy to help you out, but as I'm in Oz I'm a bit far away.
Posted 10 years 9 months ago #140611
Lol thanks for the offer - a bit far that.
Ill post up a pic of it so it can be identified.
by Markw
Replied by adamelphick on topic Radio Removal
Posted 10 years 9 months ago #140612
I find that a couple of nail files (metal ones) works for the ones that need flat 'blades' at each side to release, and a wire coat hanger cut in two and bent in to two U shapes works for ones that need 'peg' types releasers..... I sound like a radio theif now!
:nonod:
Last Edit:10 years 9 months ago by adamelphick
Last edit: 10 years 9 months ago by adamelphick.
Posted 10 years 9 months ago #140662
Thanks Dave that gives me another option.
by Markw
Replied by Leigh Ping on topic Radio Removal
Posted 10 years 9 months ago #140711
Replied by talkingcars on topic Radio Removal
Posted 10 years 9 months ago #140714
Whereabouts are you Mark, if you are local I'll happily help you take the head unit out.
The following user(s) said Thank You: Leigh Ping, Markw
Time to create page: 1.085 seconds
