centre boot brake light removal
help can some one tell me how do I remove the centre boot brake light unit on a tf 160 to repair it and do a mod to it any help will be great thankyou :dry:
mid life crisis owner, fed up with teenage kids and barking dogs, so got me a tf.
by poppy
large flat blade screwdriver and prise it out from the left then the right or the other way around but be carefull as hell ,and it is the only way to remove it (chance of breaking : high)
by paulsmgf
The following user(s) said Thank You: poppy
- adamelphick
Replied by adamelphick on topic Re:centre boot brake light removal
Posted 11 years 10 months ago #148451
Another possible way is to ease a bit of strong thin string around it on both sides as far towards the centre as it will go. Then ease either side out a bit at a time in the same way as above. The string will put less strain on the bit that usually breaks off if you manage to get it far enough towards the centre. Hope that makes sense!
by adamelphick
Time to create page: 0.459 seconds
