Sump plug washer – when to change?
- doramatadora
- Apprentice MGer
Hello :wave: I have been slowly servicing my MG TF. Great fun so far, despite 90% of nuts and bolts appearing to have been tightened by the Hulk & fossilised since.
I flushed the engine today with Forte (at 85K mi) and attempted an oil change. I could not shift the sump plug, no matter what – eventually I gave in and called a nearby mobile mechanic, who made quick work of it.
He insisted the sump plug washer didn't need changing. I've already changed a leaky cam cover gasket, and the hot, old oil was tar-like in colour, so I found it curious that he wouldn't just switch this lowly and probably ancient washer with the one that came with my service kit.
I didn't get a good look at the old washer, and it's inconvenient to try now. Should I go ahead and replace it anyway? :help:
by doramatadora
- sworkscooper
Replied by sworkscooper on topic Sump plug washer – when to change?
Posted 5 years 10 months ago #194061
Hi . Well as you say the washers are peanuts to buy but if it's not leaking , I would wait until the next oil change . And just be aware my TF was also built by a gorilla on steroids as apart from the O/S/R drive shaft nut , everything has been solid ! :pinch:
John
John
by sworkscooper
The following user(s) said Thank You: doramatadora
- BruceTF135
Replied by BruceTF135 on topic Sump plug washer – when to change?
Posted 5 years 10 months ago #194064
It really shouldn't be necessary to do these nuts up so tight! Mine was really hard to undo the first time.
All of the torque settings for the TF It really shouldn't be necessary to do these nuts up so tight! Mine was really hard to undo the first time.
All of the torque settings for the TF will be found here.
On the subject, when replacing the oil filter, put a smear of oil on the rubber seal and tighten absolutely no more than hand tight.
by BruceTF135
The following user(s) said Thank You: Bob, doramatadora
- sworkscooper
Posted 5 years 10 months ago #194065
Very good advice regarding the oil filter . I recall many moons ago working on a new fleet of Maestro vans at British Bakeries. I managed to shear off the filter casting from the block due to the filter not being oiled before installation .
by sworkscooper
- mgtfbluestreak
Replied by mgtfbluestreak on topic Sump plug washer – when to change?
Posted 5 years 10 months ago #194066
I have been guilty of oil changes and not using new washers..mainly because the washers supplied in most cases are crap...and original one left on were a better washer...if it dont leak then they dont want to be replaced...
And most filters give instructions to how tight the filter is going on..
Last Edit:5 years 10 months ago
by mgtfbluestreak
Last edit: 5 years 10 months ago by mgtfbluestreak.
Replied by talkingcars on topic Sump plug washer – when to change?
Posted 5 years 10 months ago #194075
1 useful tip for tight nuts is to try to tighten them, don't expect them to move but it might help them come undone.
by talkingcars
Last edit: 5 years 10 months ago by talkingcars.
- doramatadora
- Apprentice MGer
Replied by doramatadora on topic Sump plug washer – when to change?
Posted 5 years 10 months ago #194156
Thanks folks! I am going to assume that a professional mechanic would have oiled the filter so that I may sleep well until the next service
by doramatadora
- doramatadora
- Apprentice MGer
Posted 5 years 10 months ago #194158talkingcars wrote: 1 useful tip for tight nuts is to try to tighten them, don't expect them to move but it might help them come undone.
Timely advice – I'm going to attempt dismantling the exhaust this week. I have a dependable hacksaw I really don't want to use!
by doramatadora
Time to create page: 0.392 seconds
