water leak engine
- yellowjohnboy
- Apprentice MGer
Hi anyone had a water leak appears to be under the throttle body inlet manifold near where the stainless water pipe joins the block a bit blind to see MGF 1.8 (1998)
john
john
- Tourbillon
If you have a plastic inlet its likely to be a gasket, I got a new one and the leak went away. However the steel pipe that runs under the manifold was also corroded so that started leaking soon after ( probably damaged in the removal of the inlet manifold). I would replace the gasket with a proper spare from MGOC and try that, if you want a more robust fix, replace the pipe underneath while you are in there with a stainless steel replacement.
Last Edit:9 years 8 months ago
by Tourbillon
Last edit: 9 years 8 months ago by Tourbillon.
- mgtfbluestreak
I would scrap the plastic manifold and replace with the later alluminium one....not had to do that myself...but ive heard thats the way to go :pop:
Time to create page: 0.368 seconds
