tips for siphoning fuel
disconnect the pipe to the fuel rail switch on ignition and bump it out with the fuel pump
it will take a while but it will work
or remove parcel sheld remove fuel tank cover and undo cap put hose in ans syphon
hope this makes sence
mad about cars and bikes
if it aint broke dont fix it
- Leigh Ping
2 Do remove any cigarettes from your mouth
3 Remember to suck but not swallow
4 Make sure you do not choose a diesel powered vehicle
5 Do not breath over any naked flames for several days after doing the deed
- Rich in Vancouver
Replied by Rich in Vancouver on topic Re: tips for siphoning fuel
Posted 12 years 9 months ago #39813Put hose in tank, pump bulb a few times to start the siphon
and the flow will start.
Starting the siphon with your mouth isn't too pleasant. :sick:
Rich in Vancouver wrote: You can buy a hose with a bulb pump on one end.
yep there good but you have to get past the cap on the filler then around the 2 bends in the pipeto the tank
